Old 02-01-2003, 08:56 PM   #1
boyer64
Question ? for installing front axle for 89 chevy
I was installing upper and lower ball joints and while pulling the front hub apart, the axle pulled out of the front differential. I cannot get the axle to slide back into the differential. Is there anything that could have fallen down into the differential when I slid it out? Does anyone have any ideas on how to get it back in?
boyer64 is offline   Reply With Quote
Old 02-02-2003, 01:30 PM   #2
sakohntr
sakohntr's Avatar
axle
Which side? Is this a 1/2 3/4 or 1 ton? There should be a snapring on the end of the axle. Can you see any obstructions. Did the splines get damaged coming out? ect.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 02-02-2003, 02:02 PM   #3
boyer64
It is a 1 ton on the passenger side where the axle goes into the differential. When we took this out, we did not see any snapring.
Old 02-03-2003, 09:23 AM   #4
Blazer1970
Blazer1970's Avatar
There is a thrust washer inside the extension housing on the passenger side of those IFS differentials that will fall down and block the axle shaft from going back in. You have to remove the extension housing from the differential and put the washer back on the end of the axle shaft, and re-install the extension housing with the axle shaft as an assembly. I have seen this happen many times. The thrust washer is part of the center axle disconnect assembly. On the drivers side, you can pull the axle and shove it back in no problem.
Blazer1970 is offline   Reply With Quote
Old 02-03-2003, 04:22 PM   #5
boyer64
Talking
Thank you very much. Your directions worked perfectly. Thank you again!!
