Old 02-24-2010, 08:26 PM   #1
soala70
soala70's Avatar
steel floor repair ?????
is there a way to fix the waves between floor supports or per say "trick"
bogey5
soala70 is offline   Reply With Quote
Old 02-24-2010, 09:18 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: steel floor repair ?????
Best method for this is to remove the floor supports "cross sills (if talking bed) and hammer and dolly them straight. Not really a better way. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-24-2010, 10:24 PM   #3
nds1968
nds1968's Avatar
Where there are supports I tack welded a 2" piece of metal that was about 6" long and an 1/8" thick then pulled up on that piece of metal while I hammered down on the surrounding area. You may have to use some heat. I used an overhead crane with a metal lifting clamp to pull up with so you may have to improvise. You could tack weld a piece of chain maybe and pull on that with a chain block or ratchet strap you get the idea.
It was a lot of work. http://67-72chevytrucks.com/vboard/s...d.php?t=288104
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 02-25-2010, 01:04 AM   #4
soala70
soala70's Avatar
thanks will try to start this weekend
bogey5
