Old 02-24-2010, 09:49 PM   #1
smokinstang70
smokinstang70's Avatar
Chassis Paint vs powder Coat
somewhat new the board and starting my first build (Build thread to come). I have the chassis disassembled and am debating about weather to paint it or powder coat it.
I figure you guys have tackled all of this before... ideas?
Also, if paint... can you give me some GOOD example of what brand and type to use.
Thanks everyone.... pictures to come
P.S. this build is ALL my wife's idea... I'm letting her to most of the design and as much of the work as she wants to.
smokinstang70 is offline   Reply With Quote
Old 02-24-2010, 10:36 PM   #2
Thealien
Thealien's Avatar
Re: Chassis Paint vs powder Coat
Powdercoat is very durable and is what I would go with if you can afford it. But always a but, do you plan on any fram work in the future or are you going to do it and leave it? If you are going to do it and leave it I am still with powdercoat. If you plan on modifying at a later date I would go the paint route. There are a few companies out there with very good chasis paint POR15, Eastwood has a chasis black, there is a couple more that I can't think of right now but I am sure others will add them. I have used POR15 and am happy with it.
Old 02-25-2010, 12:03 AM   #3
MisterE72
Keep Your Nose Clean
I chose powdercoat over painting only because by the time I factored in sandblasting, primer, paint, paintbooth, and transportation, my cost was almost the same. I paid around $750 and got the frame, rearend housing, radiator support, upper/lower control arms, and trailing arms. Powdercoat is also more durable. My 2¢.
MisterE72 is offline   Reply With Quote
Old 02-25-2010, 01:53 AM   #4
AusTx68
AusTx68's Avatar
I had my frame blasted and sprayed with POR15. The rear differential and front crossmember I did myself using wire wheels and flapper disks. I like that I can go back and make changes to the frame and simply touch up the area. After this photo was taken I added an ECE drop member. I would have hated to grind and beat out rivets with powercoat.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 02-25-2010, 12:15 PM   #5
epashhans
epashhans's Avatar
Have you ever seen that old car with the "recent" paint job that looks good until you get up close and you see some bubbles where rust is eating away underneath? I always wondered if that could happen under powercoating on a frame if you weren't really careful with prep. And with it being tough and thick, would it even bubble to let you know you have a problem? Probably not a good thing on your frame where you need structural integrity. And can you touch up the powdercoat? I am assuming you can, probably not as easy as grinding away some paint and rust and then masking and painting. Especially on a frame. Mine is just a daily driver...some good cleaning and prep and the semi-gloss rustoleum has always looked good, held up well and is super easy to touch up and affordable. I know some guys have rolled it on with good results even!
Good luck whichever route you go...and show us some pics! Because as you will soon find out around here...
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 02-25-2010, 12:54 PM   #6
100gold
Here Here! I agree completely with this post. You can always freshen it up 10 years down the road.
100gold is offline   Reply With Quote
Old 02-25-2010, 02:15 PM   #7
smokinstang70
Thanks for the replys guys... keep them coming. I will definitely be putting up some pics soon. I'm definitely leaning towards paint rather than powdercoating... now just to decide what kind of paint????
Old 02-25-2010, 03:19 PM   #8
Fitz
I blasted the frame, trailing arms and diff housing and had them powder coated... $450.00.
Fitz is offline   Reply With Quote
Old 02-25-2010, 08:14 PM   #9
I don`t like powdercoating on frames of vehicles that get driven.It can and will chip,it`s not invincible.It`s a shell and when it gets a chip water gets in behind.If you can`t see the spot it will stay behind the coating and eat away at the frame while the coating stays on and looks fine,until it`s so bad it lifts away.Most people don`t see the frame enough,especially every surface to notice.I`ve powder coated a lot of parts since the`80s and have had them a long enough time to see the pluses and minuses.I just paint frames.It`s easy to touch up.
Old 02-25-2010, 09:05 PM   #10
capev86
"if" i ever need to do a frame off on my 72 burb, i will have the floor boards and chassis pieces coated in zinc primer and top coated with (a quality brand) poly bed liner. it may not be as smooth as paint, but it is tough as nails and resists impacts. on floor boards it will act as a sound deadener!
capev86 is offline   Reply With Quote
Old 02-25-2010, 10:24 PM   #11
tjsblazer
tjsblazer's Avatar
Dupont Imron is a hard as nails paint, however, not everyone wants to spray it any more these days. I think originally it was an aircraft paint so it's made to stand extremely high abrasion winds.
POR15, does it not need a top coat of paint to provide UV protection.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 02-25-2010, 10:49 PM   #12
RW71
RW71's Avatar
I used Hammerite paint on my frame, it needs no primer just knock the loose rust off and paint. This stuff is hard like glass.
RW71 is offline   Reply With Quote
Old 02-25-2010, 10:53 PM   #13
Racinaround
Racinaround's Avatar
$500 for Sandblast and Powder Coat
I took it all apart and rebolted with Stainless Bolts
I could of never cleaned it, Preped it and Painted It, to look that nice for $500
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 02-25-2010, 11:12 PM   #14
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
I've been called cheap along with many other things and did most of my fram and components at home. I sent the a arms, front cross member, front springs and trailing arms to a guy here in town to be blasted. He charged me like $60 to do everything. The frame i started with was relatively clean, so i just used one of those portable sand blasters from the hardware store and did the frame myself, not perfect but ruffed itup a bit. Then i Bought a gallon of POR15 and brushed everything by hand. I can't believe how well that stuff goes on. Lays out smooth over blemishes and there are no brush marks afterwards. If i do another i would do it the same way cause that por15 stuff is hard to scratch.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 02-25-2010, 11:20 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
I use POR15 on my frames. It is 45 bucks a quart and tough as nails... A quart will do one coat on the complete pickup running gear. I put it on with a brush and it looks like it was sprayed. I got mine at my local NAPA store but they may have to order it. I would suggest a light sandblast but you can clean the frame by hand if you want. A frame does not need to be top coated because it never sees UV rays.
Just my 2¢ worth.
LockDoc
Leon
Old 02-25-2010, 11:53 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Another option to throw in the ring....hammered rustoleum in a spray can....easy application, about 90 total in the frame including primer, the paint, and wire wheels/sanding discs...
Closeup of the black hammered
and the silver
and the whole frame completed (and dusty)
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-26-2010, 09:06 PM   #17
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by lockdoc View Post
i use por15 on my frames. It is 45 bucks a quart and tough as nails... A quart will do one coat on the complete pickup running gear. I put it on with a brush and it looks like it was sprayed. I got mine at my local napa store but they may have to order it. I would suggest a light sandblast but you can clean the frame by hand if you want. A frame does not need to be top coated because it never sees uv rays.
Just my 2¢ worth.
Lockdoc
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-26-2010, 10:04 PM   #18
smokinstang70
Thanks for the reply guys.. this is awesome. Has anyone ever sprayed POR15? Does it have to be thinned?
P.S. "I'm not cheap, I'm thrifty!!
Old 02-26-2010, 10:12 PM   #19
Racinaround
I spray it on suspention parts and sprayed a couple car frames
They make a solvent you add (just a little)
Then clean your gun a couple times to make sure all that stuff is out of it!!!
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
Old 02-26-2010, 10:29 PM   #20
Stoney
Farm Truck
Stoney's Avatar
Powder coat doesn't chip if the material is sand blasted correctly
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 02-27-2010, 03:32 AM   #21
leddzepp
Moderator
leddzepp's Avatar
It can be thinned 20% when spraying. Do it in a well ventilated area, and wear a respirator.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-27-2010, 06:21 AM   #22
Shaky
Six in a row makes it go...
Shaky's Avatar
In the past I blasted, shot it with etching primer, and then Imron. Seems to be holding up pretty well.
On the '67 I'm currently working on, the frame isn't totally stripped down. I scraped and cleaned it and when it gets warm enough I'm going to brush this stuff on:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 03-20-2010, 09:39 AM   #23
bamafrost
bamafrost's Avatar
Started with areally good frame...probably could have just re-sprayed it with Eastwood's Rust Converter and then Rust Encapsulator and been done...but OH, NO had to be anal retentive like us truck guys can be.
I wire-wheeled mine and used flapper discs...then sandblasted. Then, the weather turned too cold to blast/prime/paint (I have no covered area) so I tarped it and waiting for the weather to warm. It was 70 today...so a few more days I should be good to go with my blasting. Using Black Beauty with a hood and respirator, then I'll prime with Eastwood's Chassis Primer and coat with 2-3 coats of Eastwood's Extreme Chassis Black Gloss.
Hopefully, it'll end up worth all the time and effort. All the supplies/media has added up to about $350 and lots of time.
Bamafrost
"Wars fought, uprisings quelled,
Coup d'Etats planned...right after my nap".
'68 Rambler American 2 door post
Built 340/727/8.75 w 3.73 posi
'68 C10 shortie soon to have a 2.5/4 drop
and new Americans: 16" x 8" chrome IROC's
bamafrost is offline   Reply With Quote
Old 03-20-2010, 10:51 PM   #24
gkesseru
gkesseru's Avatar
If you live in a salt air area or any are where rusting would be a problem, the best is to use a cold galvanizing paint. I used ZRC on my boat trailer and had no more rust problems for at least 15 years with constant use in salt water. Need to sandblast first to bare metal and brush on primer in a good thick coat. It can be topcoated with a paint of your choice. My boat trailer was painted with a red car enamel car paint after a touch sand of the ZRC. For chassis' I prefer to topcoat with semigloss Rustoleum. Any small scratch through the paint and the zinc below will oxidize and seal the scratch. Even with larger scratches, the rust will not get under the zinc coat. Easy to touch up.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 03-21-2010, 09:25 AM   #25
weasel29gm
SLOW BUT SURE,BUT CLOSER
Good pics on the Hammered paint I use it on all my stuff. P/C is way overrated and over priced $500 and up for a frame that don't get looked at. Like spendin' $50 bucks a wheel for a ralley wheel thats worth $50 or less. $ 6 bucks a can touch up every year, thats savin' some $$!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
