Old 02-24-2010, 10:13 PM   #1
drag_72
Ready to go fast!!
drag_72's Avatar
Question Hellpp!
i got a 72 chevy shortbed pro street truck... ladder bars, coil overs, narrowed 9 inch... the whole nine. for some damn reason when i get on it the ass end shimmys back and forth?? i really need some help on this. the truck didnt do it until the guy before me changed the tires?? but he said he messed with the pinion angle and it got better? but its still really bad. i wanna get it lined out before i take it to the track
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 02-25-2010, 12:43 AM   #2
SCOTI
SCOTI's Avatar
Re: Hellpp!
Start w/the basics.... Make sure everything is properly fastened in place. Measure to ensure it's square. If both of those items are good, verify the current pinion angle to see where you're at (& if it needs adjusting).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2010, 02:13 AM   #3
chopped68
Re: Hellpp!
what tires were on it before and what are on it now?do the ladder bars have an adjustment on the bottom tube near the axle.if so,make sure they are adjusted equally to start with.is there multiple mounting holes for the ladder bars on the frame(normally there are 3).check to make sure the are mounted correctly.this might be a shot in the dark but as far as the tires,sidewall thickness between the 2 different tires could be a possibilty.hope this helps.
ken
chopped68 is offline   Reply With Quote
Old 02-25-2010, 03:22 PM   #4
drag_72
Ready to go fast!!
drag_72's Avatar
Re: Hellpp!
it had sportsman pro's but now it has sportsman S/R radials the tire size is 31x18 thanks i will check it out
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-25-2010, 04:48 PM   #5
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Re: Hellpp!
Does it still have a panhard bar on it? I think that's what keeps the rear from having side to side movement, but I'm also not very smart...
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 02-25-2010, 09:05 PM   #6
drag_72
Ready to go fast!!
drag_72's Avatar
Re: Hellpp!
yeah its gotta aftermarket one but its a lil loose?? im gonna tighten it and see what that does
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-26-2010, 01:05 AM   #7
72 SUPER10
Re: Hellpp!
check your center to center of front spindle to rear center axle, also check the roll out of your tires using a seamstress tape . another thing could be the shock bottoming out or shock adjustment,or weak spring,good luck,vince.
72 SUPER10 is offline   Reply With Quote
