Old 02-24-2010, 10:51 PM   #1
salrod00
salrod00's Avatar
column differences
i wonder if a 91 suburban column would fit a 82 pick up. my wipers and headlights are on my dash and suburban wipers are on the column. i want it for the tilt. but was wondering if i just plug up the ignition switch and black harness to the truck one . and everything would be functional.. thanks in advance
salrod00 is offline   Reply With Quote
Old 02-25-2010, 11:05 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: column differences
If I were you, I'd try finding a tilt column from '83-prior. In '84 is when the dimmer switch and wiper controls moved to the column. I'm not sure, but you may be able to plug it in and use it, but I would find the correct column for you '82.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-25-2010, 07:17 PM   #3
salrod00
salrod00's Avatar
well the dimmer and wipers are gonna stay on my dash board. my old column stays in run position only and cant get the key far back to take it out.im just need a quick tilt column and good key switch.
Old 02-26-2010, 06:11 PM   #4
slugish
Slugish
Originally Posted by jchav62 View Post
if i were you, i'd try finding a tilt column from '83-prior. In '84 is when the dimmer switch and wiper controls moved to the column. I'm not sure, but you may be able to plug it in and use it, but i would find the correct column for you '82.
have found a 90 burb tilt collum for my 84 as well > since my wipers & dimmers are on the collum stick , will it work on mine .
slugish is offline   Reply With Quote
