02-25-2010, 06:32 AM | #1 |
Flexplate 400ci or 350ci?
Good morning,
i´ve got a problem with my ´77 pick up. First i have to say, the engine never runs well. According to the VIN there must be a 400ci inside CKR247F511075 Whenever something´s broken down, i ordered spare parts by this number. Till now this runs without problems. But now my flexplate is broken and i ordered a newone by this number however. As i received the new, it was different. There is a balancing weight on it. After a call with the dealer, he told me that the 400ci-motor is balanced on the outside via the flexplate. So i think by myself, that this could be my problems with the engine. So i mount the new and start the engine. Immediately the truck began to shake. The balancer on the frontside of the engine is a 8", typically for the 400ci. But with the flaxplate now, i don´t know further. Is there a 350ci or a 400ci engine in? Thanks for helping Greetings Chris |
02-25-2010, 08:57 AM | #2 |
Re: Flexplate 400ci or 350ci?
Can't always go by the VIN number as motors could have been changed over the past 30 years. Best way to tell what the motor is is to get the casting number off the back of the block. Might be able to get tell by the numbers off the front too, they are behind the alternator.
It sounds like if you put a 400 flexplate on there and it shakes you have a 350.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
02-25-2010, 09:12 AM | #3 |
DO NOT run that engine anymore with that flexplate. the 350 is internally balanced having that weight added could cause severe engine problems. 8 inch balancer is not an indication of anything they were used on almost every sbc including most 350's. you need to get the numbers off the engine itself. almost every other part will interchange between a 350 and 400. the easy way to check and tell what you have is to look at the freeze plugs on the side of the block. a 350 will have 2 and a 400 will have 3.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-25-2010, 10:53 AM | #4 |
1962 C-10
I agree. Another way to tell is the harmanic balancer. A 400 is externally balanced and has a weight on the flexplate and also has a 'notch' in the harmonic. A 350 will have a smooth harmonic balancer with no notches. A 400 has a large harmonic balance with a notch machined out of it.
My guess is you have a 350... Running it with that flexplate with call damage to the bearings.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
02-25-2010, 11:11 AM | #5 | |
I can still count my vehicles on two... wait three hands. |
02-25-2010, 11:13 AM | #6 |
Get the casting number from behind the drivers side head on top of the block. You might have to use a wire brush or something to clean it but it will be very clear to you when you see it. Then post it and we can identify what engine you have. Also some 400 blocks had only 2 freeze plugs like the other small blocks so thats not always a true statement. I also posted a picture of a 400 harmonic balancer because the 400 like the 454 is balanced externally on both ends. Notice the cut out on the balancer its a very noticable difference.
02-25-2010, 11:22 AM | #7 | |
Please read these threads to identify a 400 small block. Counting freeze plugs is a wrong way to do it. Some 400's have 2 and some have 3. There are pics in both of these linked threads. http://67-72chevytrucks.com/vboard/s...d.php?t=324441 http://67-72chevytrucks.com/vboard/s...80#post2789780 Last edited by Dooley; 02-25-2010 at 11:36 AM. |
02-25-2010, 08:39 PM | #8 |
Crew Cut
i dont guess any of the old fokes want to say it, so i will. just take a chisel and knock the weight off.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
02-25-2010, 08:51 PM | #9 |
Badass
you mean you cant run the motor with out a flywheel? isnt that what a Flexplate is?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
02-25-2010, 09:13 PM | #10 | ||
You have to have one or the other, it just depends upon your transmission.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-25-2010, 09:35 PM | #11 |
Badass
lol yeah i was thinking like how are you gona start it then lol my bad
02-26-2010, 08:25 AM | #12 |
Ollah,
thank you all. tomorrow i´ll find the time i need to work on it. when i have the engine number, i´ll post it. think that i disassemble the gearbox and change the flexplate. @OJOE: i had tried it with a small angle grinder, but there´s not enough space to handle it. tomorrow will show THX chris Last edited by roadrunner-europe; 02-26-2010 at 08:26 AM. |
02-27-2010, 04:12 PM | #13 |
Ollah,
I did it. Have cut out the counter weight. Now the truck run again And to all now: Yes, it´s a 350ci. 2 freeze plugs, no cut out on the balancer and here the number 3970014 and now a new question: at the block there is a plate attached: REMANUFACTURED 6 8 1 9 7 9 What does this number on the plate mean? Are there some informations to get out of it? Don´t know, why replacing a 400ci with a 350ci Thank you Greeting Chris |
02-27-2010, 04:32 PM | #14 |
350's are a lot easier to come across and is a direct replacement for the 400. Its done pretty commonly just because of availability.The remanufactured 3 is probably just a serial number. There should be another number on the front passenger side of the block just in front of the had on the flat pad. That will tell the entire story of what the engine was originally out of. The only issue being that the engine was rebuilt. Whatever it was originally isnt neccessarily what it is now.
02-28-2010, 01:15 PM | #15 |
Ollah,
ok, thanks at all. next job is the lift-kit. greetings chris |
02-28-2010, 09:11 PM | #16 |
Crew Cut
did you knock the weight off or change the flex plate?
02-28-2010, 09:45 PM | #17 |
HORSEPOWER JUNKIE
[QUOTE=roadrunner-europe;3829067]
REMANUFACTURED 6 8 1 9 7 9 That is the date of remanufacture 6 (june) 8 (day) 1979 is the plate also with more info of bearing and bore sizing gm used a silver plate on there reconditioned motors.
67 C20 fleetside custom camper 69 El Camino 72 Camaro 52 Dodge b3b 108 pickup |
03-01-2010, 04:58 AM | #18 |
03-01-2010, 05:38 AM | #19 |
I really hate wet sanding!
wrap a rope around the balancer and start it like a briggs and straton...lol....eat your wheaties the morning you do this!
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
03-01-2010, 11:45 AM | #20 |
HORSEPOWER JUNKIE
how far are you from waldsee or mannheim?
03-02-2010, 05:08 AM | #21 |
ollah,
about 190 mls. herzogenrath is near aachen, at the frontier belgium and the netherlands. i´m 7 mls away from the jfc hq brunssum, if you know this. @westofb: or take a crank, just like good old times greetings chris |
03-02-2010, 06:33 AM | #22 |
I just sold a 014 block they were made from 1974-1976 so it was rebuilt at 3-5 years old
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban |
03-02-2010, 11:08 PM | #23 |
so can you tell if its a 383 stroker by the notch out of the balancer?
1970 Chevrolet custom camper 20 2000 F@$d F250 Powerjoke "And i still like bologna on white bread now and then" -Alan Jackson |
03-03-2010, 12:18 AM | #24 |
HORSEPOWER JUNKIE
I spent a few years in mannheim and my good friend has an autohaus in waldsee and my schwiegermutter lives in bad duerkheim
03-04-2010, 07:39 AM | #25 | |
cause my job i´m casually in the ambience. maybe one time i also can say "i spent a few years of my life in germany..." greetings chris |
