Life is Good !
A/c And Header Help ?
hey everyone I have a question about headers and the A/C compresser bracket? I have posted a pic of the problum area. Can I run A/C with headers? I have hermon (sp) headers and the bracket dose not seem right.
so dose anyone have A/C with the headers/ and could I see a pic of how it was done. or do I need to get differant headers? Thank you in advance Landon.
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
re-AC and headers
Hi Landon,
I checked mine and I do not have the bracket. My truck had headers when I purchased it and I believe that the bracket was left off when the headers were installed. It appears that the purpose of the bracket is to line the back of the compressor with the front. This would make it easier to line up the belt. I have always lined the belt by sight and the upper bracket that attaches to the intake manifold. It looks like the bracket would not be to hard to modify to fit. It appears that there is a problem with it fitting around the front exaust pipe. Mine has worked fine without it for the approx 200,000 miles I have had the truck. Did you have to midify the frame rail for the right header to fit? EdB |
A\C with Headers
Mine had the same install when I purchased it. Since then took them off. The right side like yours rubbed the frame. And was touching the brake lines, playing all kinds of hell with the brakes.
Simply use a piece of tubing to bring the bracket out to where it is almost perpendicular. You may have to grind the end of the tubing a little, depending on the header brand. Measure your old bolts, and get some new ones at your local bolt supply. Make sure they are the right grade for the job. ![]() ![]()
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
member #16
![]() Join Date: Dec 1999
I think the header companys make a fabricated bracket. I got mine at a local speed shop. Summit may have them. Good luck john
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Life is Good !
Thanks for your help guys. Landon
