402 BIG BLOCK
Any of you guys running a newer 4x4 IFS frame.
Any of you guys running a newer 4x4 Independant Front Suspension frame with your older bodies?
Did you guys run into any problems besides body mounts? any problems with the torsion bar suspension? Thanks, Bryan
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
![]() Join Date: Jul 2006
Re: Any of you guys running a newer 4x4 IFS frame.
I don't know anybody that has done this. I would assume that the wheel base is going to be different, as well as the high/low points on the frame, frame width, etc... It will be a cascading ball of wax trying to work out all the kinks in such a project. I'd just get an original frame, but if you find anybody that has done it, I'd be interested in seeing it.
402 BIG BLOCK
Not to worried about cutting the frame length and brackets to fit, just wanted to make there wasn't anything real major.
I was hoping with a newer frame i could get a better ride, brakes, and 4x4.
Can't remember his name but there is a member doing this with a 2001 frame and a duramax.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
The old solid axle setup is far more durable, serviceable, and simple.
