Old 02-25-2010, 11:23 AM   #1
CB24
crossmember swap question
Ok I know this subject has probably been beat to death but I have a question that I can't find an answer for.
I have a 69 c10 with the 4 wheel drum manual brakes. I bought an 87 suburban to do the crossmember swap so I can get the power disc brakes for my truck, the gas tank & the 700r4 transmission.
I'm just about ready to do the swap and am wondering if I can unbolt the entire crossmember as a whole assembly or do I need to remove components to successfully remove the crossmember?
I need to do this swap as quickly as possible because the HOA will flip out if I have a tore down suburban sitting in my driveway.
Any tips or ticks would be greatly appreciated.
CB24 is offline   Reply With Quote
Old 02-25-2010, 03:43 PM   #2
SCOTI
SCOTI's Avatar
Re: crossmember swap question
It can be swapped as a unit but the later model c.member has a couple of holes that won't line up 100% which will require lengthening those holes.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2010, 03:49 PM   #3
CB24
Ok so I can leave the rims & tires on with the steering & all? Just unbolt, drop, pull & swap? Sounds simple enough.
Thanks scoti
Old 02-25-2010, 05:43 PM   #4
SCOTI
SCOTI's Avatar
Sounds simple until you try & manuver that mass of stuff around (do-able, but can be a PITA....). Since I usually rebuild as I go, I leave the factory c.member in & swap the rebuilt stuff over piece by piece.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2010, 06:24 PM   #5
CB24
Will the newer stuff bolt on to the older crossmember? I thought in order to use the newer stuff you had to use the crossmember. If I can just swap the parts & keep the factory crossmember i'd rather do that.
Old 02-25-2010, 06:52 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If your dealing with the hoa id just unbolt the whole thing and swap it out that was its faster...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-25-2010, 07:06 PM   #7
SCOTI
SCOTI's Avatar
Yes, the newer stuff will swap right over to the current drum brake crossmember. If you want to use the 'correct' diameter u-bolts to retain the lower a-arm shafts (which I recommend) you need to drill the u-bolt holes out to the larger u-bolt size (I believe they're 1/2" u-bolts on the drum trucks, 9/16" on the disc trucks). The smaller ones can be re-used too & then drilled out once you get things together which will help keep the HOA out of your face.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2010, 07:19 PM   #8
CB24
Awesome! Thanks for all the info guys. I'm hoping to do this this weekend.
