Old 02-25-2010, 01:04 PM   #1
stevieB
stevieB's Avatar
A/C Help
Hello,
I want to redo my factory A/C what parts will I need. It is a 78 chevy blazer.
it had factory A/C It has the A/C brackets but no compressor, hoses or condensor.
what will i need to bring it back to life.
stevieB is offline   Reply With Quote
Old 02-25-2010, 04:25 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: A/C Help
Considering what a replacement compressor would cost you, I would consider buying an aftermarket compressor and bracket. Something like what Vintage Air uses, but cheaper. Nice inexpensive brackets are available from Allen Grove.
It will be comparably priced, more efficient, and NEW. The available rebuilt compressors that most stores carry appear to be junk. I will go this route if my compressor goes out again.
You'll need all of the parts you listed, of course, plus any missing wiring ductwork, control cables, etc. Even if the parts are still there, you want to replace your orifice tube and accumulator. They aren't considered reusable.
Any tubing, hoses, etc that are left on the truck should be replaced or flushed. I would probably replace all of the o-rings since they are an unknown at this point. It isn't that hard, and they cost almost nothing.
That's all I can think of...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-25-2010, 04:49 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: A/C Help
Checkout www.lmctruck.com You'll find detailed pictures of parts needed. R134 is more efficient with a larger condensor. A stock condensor is too small. I would try to install a larger aftermarket or a stock condensor from a 90's truck with R134.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
