Well I have tried the pickle forks and the BFH but they won't budge it.
Before I damage the thing I thought Id get the seperator. I looked up the J 23742 tool and most places want over $100 for it. Local rent a tool doesn't have one.... STUCK................................... ![]() It is a 67 C10 2wd Anybody have any ideas? Any help would be great.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Re: Lower Ball Joint is a PITA
You can use a tourch to heat up the A arm and a BFH, or try Harbor Freight for the correct tool.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
Suburban Hick
![]() Join Date: Aug 2008
Are you trying to get it out of the spindle or take the whole ball joint out of the a arm?
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
i just took the lower arm of and stuck it in the press
Redefining LowBudget
if he's using a fork I would guess the spindle from A arm
place a jckstand under the frame lower the jack about 1/4" from the bottom of the spring cup...wac in the fork from the back then go in fromt the otherside with your BFH and wack the spindle where the ball joint goes though.....the taper makes them pop right off with the spring tension
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
I just want to drop the lower arm to get the spring out and drill holes for the Airbag plate.....
Never Done?
![]() Join Date: May 2000
Whacking the spindle worked on both frames I tore down. No fork at all.
#8 | |
Maybe some heat would help Be sweet if I could just find the tool J 23742
When you loosen the ball joint make sure the ball joint nut is not all the way off. Place the frame of the truck on jack stands.
"the other guy"
do NOT HEAT the control arm. you should only use heat on suspension parts you don't intend to use anymore.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Anybody know a good deal on GM tool # J 23742
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#13 | |
#14 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I used a turnbuckle from the hardware store the other day. I just cut off the eye ends and used it as a spreader. Put it between the studs of the upper and lower ball joints and tighten it with a wrench. The screw pressure from the turnbuckle will pop it loose.
#15 |
Junior Member
![]() Join Date: Jun 2007
If all you want to do is get the spring out, just remove the top ball joint and let the lower control arm swing down. Of course use a jack under the lower control arm. In the picture, I made a ball joint buster out of a brake drum puller. I put a nut between the ball joint stud and the point of the puller (yellow arrow), then put the impact wrench to it while whacking the side of the knuckle with a BFH.
"A man's got to know his limitations." - Dirty Harry _______________________________________________ 1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker |
#16 |
1967C20,
that is some sweet ingenuity, pardon my suspension ignorance but what is a BFH?
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#17 |
#18 |
Grandpa in the rustmobile...
LOL
I know on smaller stuff (ATVs) you can hold a hammer against the a arm and 180* on opposite side slam it wiht a nother bfh and it'll pop right out. heat would help also goodluck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#19 |
#16876
I didn't even mess with my upper or lower B-joints. I just disconnected the upper A-arm from the frame and gave it a spin to get my coils out.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#20 |
its all about the +6 inches
I was reading the whole thread to see if anyone said anything... SOM got it.
If the lower ball joint is being that stubborn, then just unbolt the arm from the cross member. |
#21 |
yeah if you leave the balljoint in sooner or later it'll just fall apart on its own usually at higher speeds then all your problems are solved
#22 | ||
Not on the A-arm but on the spindle itself, right next to the stud.....and yes it works very well.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#23 |
Tool is in the mail should be here tm. I am retired from hack jobs...wrecked too many things....lol
Even the broken cotter pin was a good battle.
#24 |
Wow those suckers are in there! The tool is great with two washers.
#25 | |
72 GMC
the right tool and you'll have it forever, and the work goes much easier. |
