Old 02-25-2010, 01:51 PM   #1
53GMC
53GMC's Avatar
Steps To delete ABS from 1996 S10
Hey guys...i need your help again...
I am at the point in my project 53GMC that I need to learn how to delete the ABS from my truck....but i have NO CLUE!! The reason i want to do so is because that huge box under the hood takes up a lot of room and I need to cut down on some space...
If anyone can help me I would greatly appreciate it....I need steps, what re-wiring steps to take (colors to cut if year model is the same) and ANY and ALL info to help me.....I am lost and dependin on you great fellas again...Thanks to everyone in advance.
help me help myself!!
53GMC
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 02-25-2010, 02:42 PM   #2
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Re: Steps To delete ABS from 1996 S10
From what I know the ABS is on it's own stand alone computer which should be somewhere by the ABS pump? If so you can remove the computer, all wiring, pump, and block, and plumb the brakes straight to your proportional valve.
addicted2dunes is offline   Reply With Quote
Old 02-25-2010, 02:53 PM   #3
53GMC
53GMC's Avatar
ok....so would that big box that i have be the stand alone computer by chance? and where would the pump be located or look like? i believe I could do the rewiring bit though...
1953 GMC/S 10 Swap
Old 02-25-2010, 02:54 PM   #4
addicted2dunes
Got a pic?
Old 02-25-2010, 02:55 PM   #5
addicted2dunes
Pump should have the brake lines going to it, be cast aluminum and have a black cover on it from what I remember.
Old 02-25-2010, 02:56 PM   #6
addicted2dunes
Here's a computer
http://cgi.ebay.com/ebaymotors/95-Ch...Q5fAccessories
Old 02-25-2010, 02:59 PM   #7
addicted2dunes
ABS pump
http://cgi.ebay.com/ebaymotors/1996-...Q5fAccessories
Old 02-27-2010, 12:17 AM   #8
53GMC
53GMC's Avatar
thank you so much addicted2tunes...
that is indeed what mine looks like....ill remove them and the computer bit and re-plumb my brake lines to it all...thank you again for all your help!!
1953 GMC/S 10 Swap
