Old 02-25-2010, 02:11 PM   #1
1-PU70
1-PU70's Avatar
battery acid resistant paint
Im installing a new battery tray in my 70 and was wondering if there is some kind of paint or a coating I can brush on to protect it from battery acid. I would also coat or paint the inner fender and the core support in the area that is usually affected by battery acid. I have tried the battery mat but it didnt help much. I could just paint it and hope it lasts another 40 years but I want to sleep at night and not have to worry about what the battery is doing to my truck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-25-2010, 02:18 PM   #2
hayhauler71
hayhauler71's Avatar
Re: battery acid resistant paint
Your best bet is to buy a sealed battery or like a optima that is gel filled that do not have a tendency to leak.
hayhauler71 is offline   Reply With Quote
Old 02-25-2010, 03:42 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
......or buy an aftermarket Stainless Steel battery tray, which is not impervious to acid, but certainly more resistant.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 02-25-2010, 04:35 PM   #4
BluTrukker
BOHICA
BluTrukker's Avatar
I work on military vehicles for a living, and they still use the old style non-sealed batteries and they leak all over. We started using a product called OUTLAST, its made by Drummond. It is a rubberized coating and comes in a spray can. we use a zinc etching primer under it. It levels out pretty well, it kind of looks like rhino liner but smoother. It seems to stand up to the acid very well. we have had some trucks come in that we painted 2-3 yrs ago and the batteries were frozen and leaked acid all over. the coating prevented it from eating the battery box. I don't know where to get it, we get it through a vendor. If you use it, I recommend shaking the can for a full 10 minutes before spraying, its pretty thick.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 02-25-2010, 06:17 PM   #5
johnechi
johnechi's Avatar
You can use POR-15 for the battery tray and just about everything else you don't want to rust out.
johnechi is offline   Reply With Quote
Old 02-25-2010, 08:05 PM   #6
JimKshortstep4x4
I used POR on a battery box and it rusted out in a couple of years since the battery leaked.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-25-2010, 08:18 PM   #7
epashhans
epashhans's Avatar
What most often makes a battery leak? Bouncing around? Temp fluctuation? And does it leak out of the top or out of the side? Could a person seal some area better with something? Or is there some maintenance that a person could do...baking soda rinse now and then? I just got done blasting and painting mine so I would like to know...not sure I want to drop money on an optima yet.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 02-25-2010, 08:43 PM   #8
culp7
HickTown
culp7's Avatar
also insterested bump
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 02-26-2010, 12:55 AM   #9
epashhans
epashhans's Avatar
anybody?
Old 02-26-2010, 03:56 AM   #10
johnechi
johnechi's Avatar
One, make sure the charging system is working right. Second, a good battery helps. It doesn't have to be an Optima battery either. I have seen these fail prematurely also. Make sure you have good grounds and good battery cables and connections. Yes, making sure the battery doesn't move around helps out tons also. I'm using a CS130 105A alternator out of a 94-98 something FWD V6. Its wired to a single stud terminal with the factory fusable links (98 camaro)
Batteries don't like heat, vibration nor voltage regulators that are faulty. Batteries typically begin to boil and the water and acid tend to go up thru the fill caps or vent.
Last edited by johnechi; 02-26-2010 at 04:01 AM. Reason: trying to answer the Qs as best as possible.
Old 02-26-2010, 07:08 AM   #11
cdowns
cdowns's Avatar
powdercoat the battery tray
charging system very important// ground wire connections are important part of electrical system that people dont pay attention to
Old 02-26-2010, 08:31 AM   #12
mrein3
mrein3's Avatar
I purchased a new re-pop tray - which was a bear to fit. Since I wanted to keep it new looking I purchased a batt-matt from LMC or similar vendor. So far it looks good in there. The batt-matt is a yellow felt piece that I'm guessing absorbs any acid that spills out.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-26-2010, 10:26 AM   #13
Sub71
Buy a plastic battery tray to put under it, seal the bolt holes with silicone, no more rust problems.
Sub71 is offline   Reply With Quote
Old 02-26-2010, 01:20 PM   #14
olred68
olred68's Avatar
If you have linex bedliner near you they might spray it of 20 bucks or so
Brandon
olred68 is offline   Reply With Quote
Old 02-26-2010, 01:27 PM   #15
leddzepp
Moderator
leddzepp's Avatar
POR-15 the tray.
Keep an eye on the battery. Acid will eat thru ANYTHING if given enough time to do so.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-26-2010, 03:43 PM   #16
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
SS tray or Optima is the best solution. The acid batteries will get core sup, fenders and even hood, so you need to protect more than the tray. If you powdercoat or cover a used tray or other parts, they will bleed acid back out from inside the seams. I hate battery acid and blake fluid!!!
PICKMUP is offline   Reply With Quote
Old 02-26-2010, 05:04 PM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
What battieries are you guys using? I've owned my truck since 1996 and it's only ever had wal-mart or autozone batteries in it and I've never had a leaker? It is obvious that it had leakers in the past, as I had to replace my inner fender and a section of the core support, but I did all that way back when I first got the truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
