Old 02-25-2010, 02:54 PM   #1
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
85-86 fuse box diagram or labeled pic please!!!
the trucks birthdate is oct 18, 1985 so im guessin my body is really a 86?
im still having a problem getting a few of my guages to work. thing that stumps me is that the clock works. i know the oil pressure one isnt even hooked up at the engine because i havent put in the correct sender in. the tempguage i still need to try the correct sensor, but my battery guage does nothng either. could this just be a fuse and the clock is on a separate circuit? just wondering because none have ever did anything. and do these all have to be hooked up for one of them o work, like the power window switches are?
im thinking a fuse diagram would help since the letters are damn near all gone on mine.
thanks in advance.
knightowl73 is offline   Reply With Quote
Old 02-25-2010, 03:12 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 85-86 fuse box diagram or labeled pic please!!!
I can get you one tonight when I get home if no one gets you one before hand.
--Josh
Old 02-25-2010, 03:25 PM   #3
spinem
haha, ford guys...
well this is a basic one for our trucks,im not sure if this is what you are looking for?
# A - Fuse - Traffic Hazard
# B - Fuse - Tail, Stop Courtesy Lamps
# C - Receptacle - TP2 /M40
# D - Fuse - Radio & TCS
# F - Receptacle - C91/UF2 (Cargo Area Lamp)/U35/U37
# G - Fuse - Heater / Air Cond.
# H - Receptacle - C62
# I - Fuse - Accessory
# J - Fuse - Panel Lights
# K - Receptacle - NL2/A33/U16 (Tachometer)
# M - Receptacle - Accessory Lamps
# N - Not Used
# O - Fuse - Reversing Lamps
# P - Fuse - Instrument Cluster Feed
spinem is offline   Reply With Quote
Old 02-25-2010, 07:57 PM   #4
knightowl73
cool. well i got the oil pressure and temp guages working now, but have no clue if the temp one is reading correct. i did swap the original guage backin, it readsbelow the 200 mark, and i think thats normal. still cant get the voltmeter to work, but im going to check the brown wire from the alternator lster on.
by the way, thanks again. the diagram was spot on.
