02-25-2010, 04:31 PM | #1 |
Sofa King Crazy!!
Krinkle Paint
I am going to spray a chrome glove box door with black krinkle paint to match my gauge bezel. My guess is Eastweed Krinkle Black, and maybe scuff the chrome with some 180 grit?
1. What is the best kind of krinkle paint to use? 2. And what kind of prep should I do to the chrome?
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
02-25-2010, 04:54 PM | #2 |
Re: Krinkle Paint
a 67 glove box door has the same finish as the cluster already. like this one. if you need it pm me
1967custom |
02-25-2010, 05:11 PM | #3 |
Sofa King Crazy!!
Re: Krinkle Paint
Thanks! But I just got a new chrome one so that it would match my new chrome and black bezel. I really appreciate ya lookin out for me!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 02-25-2010 at 05:11 PM. |
02-25-2010, 05:18 PM | #4 |
Re: Krinkle Paint
get wrinkel paint from loal discout autoparts store and save on shipping// to make it wrinkle good i use a 100wattbulb in a cheapo aluminum reflector to heat it and make it work good
02-25-2010, 05:41 PM | #5 |
Sofa King Crazy!!
Re: Krinkle Paint
Cool. So warm it up a little while it dries, got it. And just scuff the chrome?
02-25-2010, 05:43 PM | #6 |
Six in a row makes it go...
Re: Krinkle Paint
I've used Harley-Davidson black wrinkle paint on other things. It's pretty durable. If you like the way their engines look, it might be something to consider...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
02-25-2010, 05:52 PM | #7 |
its all about the +6 inches
Re: Krinkle Paint
I've done this in the past... twice, and if I do it again (I plan on it) I won't do it the same way you describe.
I would order a woodgrain sticker, and paint that with the black paint, then stick it on. Less chance of tape lines, leaves the dimple around the button chrome, and would look better all around. I always put duct tape on the edge of mine, and tossed them in the sand blaster to prep the chrome. |
02-25-2010, 07:01 PM | #8 | |
Sofa King Crazy!!
Re: Krinkle Paint
02-25-2010, 09:04 PM | #9 |
SWB 4x4 Collector
Re: Krinkle Paint
I really don't recommend the woodgrain idea. The aftermarket woodgrains tend to shrink and peel if not properly applied. You wouldn't want your paint flaking off. I think you are best off masking with some good 3m masking tape, and spraying light coats to build up the wrinkle finish. I am about to restore a 67 glove box door as well. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-25-2010, 09:10 PM | #10 |
The Older Generation
Re: Krinkle Paint
I agree with Andy on sandblasting the area you want to paint. If you don't I don't think the paint will stay on the chrome very long. LockDoc
02-25-2010, 09:38 PM | #11 |
Watch out for your cornhole !
Re: Krinkle Paint
Have it powdercoated. It's much more durable.
Here is one I did in silver then wrinkle powder on the insert. It was a junk, rusty door that I just did to play with the technique. .. Here is a picture of some valve covers I did yesterday. Wrinkle powder is the bomb.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 02-25-2010 at 09:40 PM. |
02-25-2010, 11:31 PM | #12 |
Happy to be here
Re: Krinkle Paint
Very true. You will end up with a very uniform finish too.
It is "very" important to apply wrinkle paint evenly with minimal overlap. I would recommend preheating the surface evenly as well.
