Old 02-25-2010, 05:48 PM   #1
Crispyr1
Crispyr1's Avatar
Putting in a radio and speakers, need help
I'm getting ready to put a radio in and some or one speaker. Need suggestions and ideas. I don't have the money to put in one that will fit brand new, so I will probably be cutting the dash to fit a CD player. Pics would be a plus too.. and also there are no wires for it so i'll have to run those aswell! thanks for the help guys!!!!
Crispyr1 is offline   Reply With Quote
Old 02-25-2010, 05:49 PM   #2
Nova70
Nova70's Avatar
Re: Putting in a radio and speakers, need help
What exactly do you want ideas for? Speaker location?
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 02-25-2010, 05:53 PM   #3
Crispyr1
Crispyr1's Avatar
where to put my radio if there are alternatives, how to cut, speaker location, wiring it up. I'm a newb and just trying to make the job easier. figured i'd ask you guys.
Old 02-25-2010, 06:01 PM   #4
Nova70
Nova70's Avatar
As for wiring, it's pretty simple. You'll need to run a constant 12v wire, switched 12v (Usually from ignition switch) and a ground. The rest is your speakers. I cut my dash and it was pretty easy, I just marked it all out with a sharpie then cut it with a jigsaw. Make sure you measure 3 times and cut once.
Old 02-25-2010, 06:07 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
I masked my opening to the measurement the stereo needed and cut with a Dremel. X2 on the measure 3 times part.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-25-2010, 07:03 PM   #6
Crispyr1
Crispyr1's Avatar
where did you mount the speakers? i heard of using the kick panels, but looks like it takes up a lot of room. I also heard of using the air ducts on the side wall, but how would you seal the back of the speakers from the elements?
Old 02-25-2010, 07:06 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
My speaker are in my doors, courtesy of the PO hacking holes for 6 x 9's and 6" round ones. Sounds good, but if it were up to me I would have put them in some kick panel pods.
Beat it to fit,
Old 02-25-2010, 07:22 PM   #8
Nova70
Nova70's Avatar
I just made some kick panel pods and love them. As long as you go with a quality component set that will be plenty of speaker. Throw in a sub somewhere and you're good to go. I'm running the Image Dynamics CXS64 V.2 in mine along with a 4" 2-way coaxial in the corner's of the dash. Just make sure you run the comp. set off an amp.
Edit- Not sure what your budget is speaker wise but here is the comp. set I'm running and it's the best I've run so far.
http://www.woofersetc.com/p7174/CXS6...ent-System.htm
If you're on a bit more of a budget I've heard nothing but good things about these I.D.'s-
http://www.woofersetc.com/p6201/CTX6...ker-System.htm
Old 02-25-2010, 08:00 PM   #9
Ironhorse
Ironhorse's Avatar
I haven't done it yet but after moving my in-the-cab tank to under the bed my thoughts are to put a pair of 6" x 9" tri-axials in the cab corners facing at an angle toward the cab center. Truck is sleeping off the winter doldrums right now so am looking for any thoughts on how to mount such a set-up. Figuring on using 1/2" plywood covered with grey cloth to match the interior.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-26-2010, 01:36 AM   #10
Nova70
Nova70's Avatar
Just my .02 but 6x9's are not built for sound quality. I would go with a component set if I were you. I also wouldn't put speakers behind you in a single cab as it will set the sound stage off. I'm anal when it comes to audio if you can tell.
Old 02-26-2010, 01:48 AM   #11
bikerbuck
My tank is under the bed so ive got a speaker box with 2 polk 10's behind the seat along with 2 corner cab speakers for the highs and 2 more speakers for the highs in the kick panels, 2 amps under the seat along with 2 layers of fat mat throughout the cab..It sounds very good.
bikerbuck is offline   Reply With Quote
Old 02-26-2010, 02:03 AM   #12
Nova70
Nova70's Avatar
I could get into a religious debate on this topic but I will save my membership. If you want my knowledge send me a PM.
Edit- If you want a system that sounds good to both the average Joe, and audio fanatics, don't put speakers behind you. If you don't care, then put them behind you.
Old 02-26-2010, 07:21 AM   #13
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
That's it in a nut shell. Run your constant 12V for memory, 12V switched, you should have 4 tabs to plug into on the right side of your fuse block for your switched power and a couple on the upper left and center for your constant, and your ground. On your speaker wires solid color is pos. and striped is neg. if this matters. The P/O had cut the dash in my '69 so I put in a Kenwood face unit from Crutchfields, $89.00 for stereo and two round 6" speakers. Pretty good deal and I like mine. Here is a pictureName:  stereo1.jpg
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Last edited by Camaro_nut2001; 02-26-2010 at 07:23 AM. Reason: Forgot to add a plugin, sorry.
Camaro_nut2001 is offline   Reply With Quote
Old 02-26-2010, 01:43 PM   #14
D-Rat
D-Rat's Avatar
Here's my install thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=376978
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 02-26-2010, 01:57 PM   #15
Hubscrub
Cruzin
Hubscrub's Avatar
i used the dash center speaker and bracket to mount two 3 1/2 in speakers in the dash where the oringinal center speaker was (if the parts are still in your truck) i cut the original speaker down and kept the bottom and magnet that fits in the bracket and welded a flat piece of sheet metal on the old speaker and the magnets from the new speakers will hold them in place and they will bolt right in place of the factory speaker you might have to bend to bracket down some i just put mine in last saturday sorry no pics
Hubscrub is offline   Reply With Quote
Old 02-26-2010, 02:50 PM   #16
jeffro788
jeffro788's Avatar
If you can afford it, the kickpanels are a good way to go, whether you run a good set of coaxials or components. The components are going to sound better, but cost you more. The last set I bought was around $500 and I will never do that again, so I bought a good set of Kenwood coaxials (only b/c I got a good deal on Kenwood 6x9s). I have the 6x9's under the seat which would be much better when I get them to stand up facing the front of the cab. All of my speakers are on an amp, so they are pretty loud and I have the amp adjusted to good sound quality. I am really not one for cutting the dash, but you will have better options for head units especially for adjustments to the system.
I have done the stereo competitions and wrapped up a retarded amount of money in a stereo and in the end it really isn't worth trying to go big, but quality is a big deal. Do what is going to fit the truck and fit your budget, hit best buys and get open box buys or the web for good sales.
If you can do it though, go for the kick panels and get them empty to put your own speakers in them, just make sure they have 2" or less mounting depth. The best deal I found was dreamers hot rods and I think we had about $85 shipping included.
1972 Chevy SWB - ZZ4 crate motor, 700r4, makes lots of noise! - SOLD
1987 Chevy SWB - SOLD
2000 Chevy SWB - 6.0L heads, Lunati cam, Whipple supercharger, 3.73 posi, caltrac traction bars, headers, custom tune and Borla race muffler. 500 H.P.
1970 Oldsmobile Cutlass 442 w-30 - original
jeffro788 is offline   Reply With Quote
Old 03-01-2010, 01:16 AM   #17
Crispyr1
Crispyr1's Avatar
You guys are awesome!!!! Thanks for the great input! I'll post pics when i'm done!!!!
Old 03-01-2010, 01:27 AM   #18
Racinaround
Racinaround's Avatar
I cant find it today but theres a pretty stock looking radio on ebay that had AM/FM and a pod hook up
No Cutting the Dash and before you know it cd's will be replace with mass storage devices (Ipods)
Sound like a starter choice?????
Just my 2 cents
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
