rear spring question. please share your thoughts
i have a 72 blazer with a 6 inch lift.. blocks in the back. i wanted to get the same spings for the rear (skyjacker) but i found a local guy that can get me a brand new pair of procomp for $400..skyjackers are 800. my question is .. is procomp springs any good? or should i just shell out the 800 for skyjackers? thanx guys
Shake and Bake!
![]() Join Date: Feb 2010
Re: rear spring question. please share your thoughts
ProComp Makes a quality product from my experiences with my new trucks. I wouldn't hesitate a second to put their products in my rig. And $400 off, makes it an even easier decision lol.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
i just want to get a little input before i deside.. im not cheap but thats a deal.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have procomps on my toyota and they are junk.... They sag and I am generally not happy with them...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
About 4 years but they started saggin after 2.
a rear shackle flip is another idea.. diy4x.com or ORD sell them.
moved to 4x4 area for more visibility
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 02-26-2010 at 11:00 AM. |
Certified Hobbiest
definitely check out the shackle flip.
a better route to go for sure. you can use your existing springs, keep your lift (may need to use a longer shackle or a smaller lift spring) and net better travel numbers all for under $400 easy. i have 6" springs in back and am gathering parts to do a shackle flip and frankenstein 56" pack. Last edited by 70 beast; 02-26-2010 at 02:57 PM. |
![]() Join Date: Feb 2001
I wouldn't go the $800 route.
Certified Hobbiest
id have to agree with mudder, $800 seem way to much. there are so many cheaper routes.
i got my 6" lift springs for $360 |
#13 |
Certified Hobbiest
ohhhh. Canada...that makes sense. well...there's always the shackle flip
#14 |
does anyone have a picture of a shackle flip?
#15 |
is there any down sides to doing a shackle flip?
#16 |
Certified Hobbiest
heres a shackle flip that a buddy of mine made using a stock rear hanger its the same idea as far as flipping the shackle position |
#17 |
406 SB 700R4 NP205 Twin Stick
![]() Join Date: Jul 2009
I did a shackle flip this past weekend, and other than making a SH*T ton of noise, everything went fairly smoothly. I used the 4" kit from ORD, and the 1" Zero Rate Add-a-Leaf "block" they have and got just about the right amount of lift I was looking for. my goal was to get rid of the 6" block too. The only part that I would recommend is to also buy a longer shackle from either ORD or DIY4X, to pick up that last inch of lift. something of mention though, if you went with a 6" leaf spring lift in the back, your springs would be rather arched to obtain that lift, and a higher arched spring would cause a harsher ride. with the shackle flip, my ride is actually better than with the blocks.
