Shake and Bake!
![]() Join Date: Feb 2010
Is 3" too much lowering on blocks?
Hey guys,
I am having my lowering blocks made at my buddies fab shop, I am having him make a 2" kit out of thick wall 2"x2" square tubing. And then 1/2" add on blocks out of 1/2" flat bar. So my question, is going 3" on blocks going to cause any issues you know of? Or will anything need to be changed? I have seen some guys do it with bagged trucks but mine is all stock height right now. Cause man does this truck sit all stink bugged out (raked) right now, I don't think that 2" is going to do much or get me level. Thanks guys.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Re: Is 3" too much lowering on blocks?
The main issue is the scrub line youll want atleast a 17in rim
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Shake and Bake!
Ah, I totally forgot about that. I am hoping to go with 18" or bigger so I should be good with a flat, but hope it doesn't rub on stuff when normal driving like different heights in the road or something.
BlahBlahBlah
The scrub line thing is important to me, and I see it come up when we talk drop using blocks. But when bagged trucks that drag frame or obviously are below scrub line no one says a thing, just how cool it is. I find that amusing LOL.
Shake and Bake!
Yeah, that is funny. Guess its the way we all look at things sometimes.
Shake and Bake!
by the way, CG, those wheels in your sig pic are swweeet. Do you have those on your truck? Link to a pic?
My Carbon Footprint
I started off with about 3" blocks and not only did it seem to affect my pinion angle but it also gave the rear end a feeling like it was "walking" on me. It's kind of like with a leaf rear end.....when you pull the axle away from the spring, you are giving it more leverage to axle wrap. This is what make a car wheel hop real bad under super hard acceleration.
I wound up going from a 4" drop to a 6" drop rear spring and then just did a very small block with a pinion angle shim and it made a big difference in the feeling under power. My motor has a ton of torque too, being a 460 BBC. That might have magnified things. I'd get as much, if not all out of a lowering spring and go from there. P.S. I just realized that I don't know if you have a coil or a leaf rear end. Bottom line is the same issue applies to both. If you drive like a grandma or have no power.......probably won't be a big deal then. Last edited by prostreetC-10; 02-25-2010 at 10:17 PM. |
The Older Generation
Myself, I don't think I would go over 2" with blocks. Just one of my personal quirks... LockDoc
Shake and Bake!
Thanks guys, I am going to see what 2.5" looks like and go from there. Another question is at what point am I going to have to worry about the panhard/trac bar? at what drop do you need to get an adjustable bar?
the bigger the stilts the less stabil the platform
bagged trucks can also add a little air to raise them back up ... blocks, not so much.
My Carbon Footprint
That's a great analogy!
When it comes to the panhard bar, the adjustable one is just too cheap not to have. Do you even know if you rear end is centered in the first place? It's a great tool and worth the little $$$. |
