Old 02-25-2010, 10:30 PM   #1
low86c10
rear window swap
how do i remove the rear sliding window?
low86c10 is offline   Reply With Quote
Old 02-25-2010, 10:38 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: rear window swap
if your rear window is like mine there was a strip in the center of the rubber gasket. First I pulled that out real careful not to pull too hard to break it. Then from inside the cab i started at the top drivers side and using two medium flat head screwdrivers i pulled the edge of the gasket down and held it with one screwdriver, then i slowly went about aninch away and did the same again and applied pressure to the window pushing it out... went another inch or so and did it again etc and it started to slowly push away once i got enough done you can just carefully push it out and then climb in the bed and pull it totally out.... if youre not using the gasket over you can just cut the rubber gasket inside and pop it out that way
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
