02-25-2010, 11:34 PM | #1 |
73-87 drive shaft clearance
Hey guys I haven't put my drive shaft in yet.. Those of you who are bagged are you dealing with anything cab clearance issues.. If so are you guys running 2 piece dive shafts?
Thanks alot guys! Billy Last edited by draggin86; 02-25-2010 at 11:35 PM. |
02-26-2010, 12:08 PM | #2 |
Happy to be here
Re: 73-87 drive shaft clearance
I had to look up your build thread to see what your truck was. In "most" 73-87 applications the cab is not an isssue like the 67-72's. In your case all bets are off. With the set up your running, it might be necessary to go two piece.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-26-2010 at 12:11 PM. |
02-26-2010, 01:37 PM | #3 |
It'd be alot cooler if you did
I had to cut a small amount out of the bottom of the cab on my ride. The motor is in the stock location.
02-26-2010, 09:14 PM | #4 |
Ok I should be laying on a 20" wheel with a 285/30/20 more wis would be stock location with a 4l60e.. If that helps any!!
