Measures to Increase ROOM for the Driver
Hi,
I have been in this battle for a while now, and I'm just curious if there MIGHT be another trick out there that I haven't thought of. PROBLEM: Being too tall and having the steering wheel of my '78 single cab touching my genitals. CAUSES: Height and Weight of driver, small amount of room between the steering wheel and the seated position of driver in '78 Chevy. SOLUTIONS: 1. Get a smaller diameter steering wheel 2. Modify steering column so that it's shorter 3. Replace steering column with an aftermarket column that is shorter 4. Replaces seat with a different seat that has different mounting brackets and somehow is back further against the back wall of cab. 5. (This one is nasty) Remove gas tank. Buy rear-mounted gas tank. Cut the "bump" on the cab floor that was caused by the gas tank being there. Modify this bump to become more of a flat continuation of the cab floor. Adjust seat accordingly. Are there any I've missed? thanks in advance. |
high-Tech Red Neck
Re: Measures to Increase ROOM for the Driver
I just stuff a smaller wheel in my trucks, im 6'1 285 lbs, I have pretty large legs, I can squat 600 lbs swapping the wheel works for me.
"He used to be a pretty nice feller, now he's a welder!" |
i think a steering wheel will be the easiest solution. thats why i got a crew cab im 6,3 250lbs. need some room...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
yeller
You could lose weight...just another option, no offense or anything.
![]() I am 6-5 215, and have plenty of room. I would start with the wheel first, then try perhaps a 88+ bench...I think they are thinner on the bottom and back.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 02-26-2010 at 01:13 AM. |
I would try the wheel first, is easiest and cheapest and go from there. I put a smaller wheel in mine and made more room. I'm only 6' 215lbs but my buddy is 6'4 240lbs and he said he feels good behind the wheel.
#6 | |
high-Tech Red Neck
![]() ![]() He takes up a little realistate.
1) i don't like 1,2,3,or 5.
2) you must be pretty big to have the steering wheel touch your junk. 3) Have you tried looking for a tilt column? Which should be bolt-in. |
At the body shop.
I put a 91/92 seat. Gained belly and leg room.
" That didnt make it any newer " " Dont antique the equipment " |
I use these wheels on all my trucks. Caviler/Lumina cars and vans. My old 84 that I just traded had a worn out seat, with the stock wheel it was fun getting in and out and not too much room. Swapped out the wheel, had plenty of room. Even if I didn't need the room, I swap them anyway, stock wheel is like a friggin ferris wheel made out of spaghetti. Crew cab is getting one too.
http://rides.webshots.com/photo/2429...43830172QRScks
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 02-26-2010 at 08:57 AM. |
I'm 6'5" / 250. A smaller steering wheel was all I needed, but all the squares I've owned had tilt columns.
You must have elephantiasis of the junk.
I am 6'2" 275 and I have no issues even with the tilt wheel even in the lowest position.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck 1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac |
dang its hot
6'1".240...smaller wheel...moved column 2" inches forward...perfect
#13 |
No No
My seat was trashed so I got one from an 88 burb and swapped the brackets. It gave me a few inches of wiggle room. I do have a full size wheel grant GM wood grain. I have plenty of room once in, getting in isnt bad just need to keep my phone in the left pocket. I do wish my wheel was a little further toward the dash but I live with it. 6'5" 280.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#14 |
Cut your junk off..........
06' GMC 1500 Crew cab..... |
#15 |
I think it depends on the seat,
my '82 C20 kinda feels cramped, but the '87 I just picked up has plenty of room. I have an '84 with an awesome aftermarket seat with a fold down armrest, don't ask me what it is, I don't know.
'87 GMC K2500 Factory 6.2 Diesel, 4 speed. Converted to 350 (has cracked block) converting back to 6.2 ![]() '82 [COLOR="Sienna"]Cadillac Coupe Deville 350 DIESEL '93 Chev S10 2.8L 5 speed '98 GMC K1500 Z71 ext cab shortbox 6.5 DIESEL '96 Ford F250 7.3 Powerstroke |
#16 |
6.0 powered square
I'm about 6' 3" with my after market seats, tilt and a 12" wheel I have plenty of room and there very comfortable , but with the stock bench I had in there for a couple of weeks felt uncomfortable, I was really close to the steering wheel, and I had to have the tilt all the way up
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#17 |
I remember the difference between my old worn out seat foam and the new seat foam was significant. I definitely sat up higher once the upholstery shop was done with it, but it was way more comfortable and I was in a better driving position.
Maybe find some thin seats out of a small car, or some light weight racing style seats ? Any seat that would allow you to position them further back and lower to the floor than the stock bench. Small wheel will help, but some have long adapters that put the new smaller steering wheel even closer to you which defeats the purpose. Get one that's small, but bolts on the same way the stock one does and sits in the same position.
1977 GMC Sierra Grande |
#18 |
Redneck Customs Bumpers, IA
tilt colom and smaller stearing wheel worked great for me, I'm 6' and 350lb (not fat but built) the tilt alone helped emencly in my truck beind as I lost space replacing my seat with a split bench out of a 93
