02-26-2010, 02:00 AM | #1 |
Power Steering
If I put a MII in my 1950 truck which comes with rack and pinion do I still need a power steering pump
02-26-2010, 02:30 AM | #2 |
Cancer Survivor in the making.
Re: Power Steering
It depends on whether you choose a power rack or a manual rack.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
02-26-2010, 02:34 AM | #3 |
Re: Power Steering
i chose a power rack does this mean i still need to use a steering box
02-26-2010, 02:40 AM | #4 |
Re: Power Steering
If you have power steering of any sort you need a pump to provide the power. If you have a rack you don't need a box. If you have a box you don't need a rack.
A Mustang II is almost always a rack and pinion, and you can choose power or manual, but once you choose power you have to have a pump.
02-26-2010, 11:08 AM | #5 |
Re: Power Steering
Thank you for clarifying that
02-26-2010, 11:30 PM | #6 |
Re: Power Steering
And be aware that GM pumps put out about 1200psi and the MII racks use 700-800 psi (I think some of the T-Bird racks use a higher pressure). The high pressure differential makes for twitchy steering.
02-26-2010, 11:34 PM | #7 |
gets board easy.......
Re: Power Steering
do you think changing the spool valve would let the GM pump work with the Mll Rack?
02-27-2010, 12:17 AM | #8 |
Re: Power Steering
If you mean the valve at the outlet of the pump where the hose connects...Yes! Borgenin Steering sells a shim kit for about $20. Each shim drops the pressure 100psi.
Just look for a Borgeson-Mullins shim kit #899001. Last edited by Atomsplitter; 02-27-2010 at 12:18 AM. |
02-27-2010, 02:24 AM | #9 |
Re: Power Steering
yup, the kit is super easy to install.
02-27-2010, 11:31 AM | #10 |
Re: Power Steering
trying to find the shim kit but cant find it.
02-27-2010, 02:37 PM | #11 |
Re: Power Steering
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
02-28-2010, 12:42 AM | #12 |
Re: Power Steering
a spool valve from another GM rack car might be worth a try???
12-15-2012, 01:09 PM | #13 |
Re: Power Steering
Hello,
Will the Borgenson kit work on a 2002 LS1 PS pump? Thanks! |
12-15-2012, 04:54 PM | #14 | |
Re: Power Steering
I'm not sure on that one Cruisinforty but most of the internals of the Saginaw pumps are the same across the board except the spool valve and spring. I went hunting through the net and came up with this. http://www.hotrodhotline.com/content...ove-components I think the main difference between pumps is the type 1 or type 2 that Allen Grove mentions.
12-16-2012, 12:24 AM | #15 |
Re: Power Steering
I have read that that works.
