![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Rear diff tricks???
Howdy folks,well one thin leads to another! Im making steady progress towards the poor house and divorce on this 72 Chevy C-10 LWB. Before I install the new brake cylinders I thought I may as well see about axle seals,yoke seal(which is wet with oil)and cover gasket. My question is; Can these 12 bolt rear ends be made into a limited slip or positrac type rearend? Or do you have switchout the whole rear end for another type? I seem to remember a kit that installed and would lock both axles. Input? Ideas? Thanks you guys!
mini truck racer
Re: Rear diff tricks???
The 12 bolt truck 8.875 axle has a pretty good aftermarket following as far as posi/locker selection goes . No need to swap the entire axle . The eaton posi seems to be well liked .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
![]() Join Date: Feb 2004
Yes the eaton posi works great, a little pricey for my blood.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
best "trick" i know of with rears is to have money and drop off at a shop for rebuild then pick it up in a day or so
Farout! Thanks guys,Im going to eatons website now
http://www.summitracing.com/parts/PWT-1910-LR/ I used one like this and works great and takes less than 1 hour to install.
Moderator
![]() Join Date: May 2007
Click on my build link below. I recently changed all the seals and gasket on my rear axle.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#8 | |
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Call Richmond gear for your application mine was a 12 bolt in my 71
motor exploder
x2 on that - just tell them what ratio you want and what diff. Eatons are good, but kinda pricey, I had an Auburn 'High Performance' LSD in my '92 C1500 w/ 10 bolt and it worked great. I would recommend it, and the price is good too. I got mine through Jeg's, but had the rearend with new 3.73 gears professionally set up.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
We just redid the complete rear end in my truck. It came out perfect and it definetly has held up nicely, no noise...highly reccomended!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 02-26-2010 at 04:37 PM. |
I got 3.73 Richmond gears with a Detroit True Trac locker
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#13 |
I thought 12 bolt rear ends were positrac. My 69 has a 12 bolt , and it is a positrac.
#14 |
Some are, most are not.
Brett |
