250 inline 6.. headers, cam, intake, 4 brl??
I have a stock 250 in my c-10 short bed chevy.
I have headers and a four barrel intake from clifford racing. I am looking into getting a 264 Hydro Clifford Cam (comes with lifters, pushrods, springs and retanor clips), as well as needing to get a Webber 38 Carbuerator to go allong with the package. I am looking to gain a little power but still keep a nice ride to where i dont have to work on the motor every weekend. I want to be able to start it up and drive it without having all of the problems that I am having with my single barrel carbuerator that is on the stock intake right now. If anyone has any sugestions I am all ears. Also If you know of any other companies other than clifford racing 6=8, where 6 cylinder parts can be purchased? Thank You |
Out of the carpool lane.
Re: 250 inline 6.. headers, cam, intake, 4 brl??
That will be a nice setup and will work well for you. For a little cheaper carb, an Edelbrock 500cfm would work very well right out of the box. Also, the Offy intake might work a bit better over the Clifford.
www.stoveboltengineco.com is run by Tom Langdon and is a great company for 6 cyl parts. There's also a supplier in AZ, but he mostly deals with the earlier gen 6 cyl's.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Too Dumb To Know Better
Have some head work done. Bigger valves and mill the head.
I am a Referee of life.
Before doing any mods I would first do a compression check and make sure the engine is worthy of the upgrades.Like low'n slow said the heads need help on these 6 cyl.They flow like molasses.
I would suggest the first upgrade be an HEI.By far one of the best mods to do to any truck of this era.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Dec 2009
Good info here guys!
Thanks for the info everyone, I did rebuild this motor about 5 years ago taking it down to the block and having it boiled and new pistons along with everything new from the crank to the velves, so it is still a new motor, and only has about maybe 20,000 miles on it.
I am going to look into that Edelbrock 500cfm. |
Most any cam grinder makes cams for the GM I-6. Crane, Crower, Erson, Isky, and Schneider are a few that come to mind. Doug's, Hedman and Hooker make headers. All you gotta do is look around...
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
Six in a row makes it go...
![]() Join Date: Mar 2009
Get this:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#9 | |
Having done the engine recently, I might not be telling you anything but for anyone else reading..... welll... and, I haven't posted in like 6 months I don't think!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
+2. It's the first thing I do with a new truck.
How will you set up the Carb linkage? I just install the Clifford Man with Edle Carb and now I am trying to figure out what to do about the Throttle Linkage. Lokar Cable?
I used a '71-'72 throttle cable set-up. I hacked it together quickly, so it ain't pretty, but it worked. What do they say? "There's nothing so permanent as a temporary solution".
#13 |
Thanks, I know where there is a 71 at my local Junkyard, I dont see the Kick Down Cable, is yours Manual?
#14 | |
I used the whole '71 gas pedal assembly.
