Old 02-26-2010, 02:56 AM   #1
85silverbeast
85silverbeast's Avatar
85 silverado accelarator
I changed spark plug wires, spark plugs and cap and rotor, the problem is now when I start it is fully accelerated I looked at the throttle cable and it doesnt seem to be stuck anywhere, any one have any idea of how this happened , maybe i disconnected something when i was sitting inside the engine compartment doing my thing.
85silverbeast is offline   Reply With Quote
Old 02-26-2010, 10:02 AM   #2
silvereagle07
silvereagle07's Avatar
Re: 85 silverado accelarator
Check to see if the throttle is closed all the way. Linkage on carb or cable may be binding. Remove the cable from the carb and see if it moves freely. I've had them bind in the plastic sheething at the pedal.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-26-2010, 03:25 PM   #3
Zoerb
Zoerb's Avatar
Also check out your return spring for the throttle cable. I've had it catch on a coat and get sent sailing accross the garage.
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 02-26-2010, 03:43 PM   #4
Damien
Damien's Avatar
Is the throttle fully open, like when you push the peddle it is already on the floor, or is it a high idle and the peddle still moves? You might have disconnected a vacuum line. The vacuum going to the brake booster will definitely make the engine high idle if it is disconnected.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 02-26-2010, 04:03 PM   #5
silvereagle07
Yep that could do it!
Jeramy
'85 Chevy 4X4 SOLD
Old 02-26-2010, 05:18 PM   #6
85silverbeast
as soon as I turn on the truck the idle is real high and peddole still moves so im gonna go chech the vaccum line that goes to the brake booster thanks for your help I really aprreciate it
Old 02-26-2010, 05:42 PM   #7
85silverbeast
I fdid fid that one of the brake booster vaccum lines is disconnected but know I dont where it goes to , thanks for your help I appreciate it
Old 02-26-2010, 05:58 PM   #8
85silverbeast
you guys are good man I plugged the booster line cause i dont know exactly where it goes and the problem stopped its running like a champ now shoul I run it like that or connect the vaccum line where it goes
Old 02-26-2010, 06:14 PM   #9
silvereagle07
Reconnect the vacum line.
Jeramy
'85 Chevy 4X4 SOLD
