Old 02-26-2010, 09:45 AM   #1
A69C10
10 bolt or 12 bolt rearend
I have a 12 bolt 6 lug 3.73 rearend but I can get a 10 bolt 5 lug 3.08 rear. Ratios don't matter as I want a 3.42 aftermarket anyways. But which one is better 12 bolt or 10 bolt (motor is only 400 horse strong)
A69C10 is offline   Reply With Quote
Old 02-26-2010, 10:30 AM   #2
cdowns
cdowns's Avatar
Re: 10 bolt or 12 bolt rearend
12bolt truck
Old 02-26-2010, 10:51 AM   #3
NINERS1
NINERS1's Avatar
12 bolts are stronger but 10 bolt will handle 400 hp.
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline   Reply With Quote
Old 02-26-2010, 11:17 AM   #4
Hart_Rod
Hart_Rod's Avatar
I've got 600 hp behind my 12, I wouldn't even consider a 10....
Hart_Rod is offline   Reply With Quote
Old 02-26-2010, 07:10 PM   #5
Mike C
Mike C's Avatar
OK, this has been beat to death but one more time. And NOT 8.2 10 bolt, they are exceptionally weak. (passenger car from early 60's through 72)
8.5" 10 bolt has 10 bolts holding the ring gear to the case. The 12 bolt has (surprise!) 12. But the 10 bolt has larger diameter reverse thread bolts that do not require the lockwashers the 12 does. So this is a push.
8 4/8 ring gear of the 10 compared to the 12 bolts 8 7/8: mostly irrelevent 3/8 inch increase in diameter. Gear material is way more important.
12 bolt has 30 spline axles while 10 bolt has 28. This is a win for the 12. Until '88 when GM switched to 30 spline axles on the 10 bolt.
Pinion diameter is larger on the 8.5" 10 bolt, it is the same as the passenger car 12 bolt. Advantage 10 bolt on this one.
In the end, both are about the same strength wise stock. The biggest cause of failure in either is the one-wheel-peel or wheelhop. Parts are about the same price for each and aftermarket parts can be had to beef up both.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-27-2010, 03:28 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is no reason to spend the time and money to convert a 10 bolt rear, spend that money on 5 lug axles if thats what you are after.
Old 02-27-2010, 03:38 PM   #7
Keith Seymore
Keith Seymore's Avatar
Guys - I have had a 8.5" ring gear 10 bolt in my Chevelle for 32 years - no problems.
The car is currently around 900 hp.
Shouldn't be any issue for a (I assume) street driven pickup truck.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-27-2010, 04:08 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
K
where are some pictures! You can't tease us with a 900 hp chevelle without a single pic!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-27-2010, 04:29 PM   #9
AusTruck
I'm thinkin' the 8.5 rear end was also used in the Turbo Regals and guys are putting some incredible amounts of hp and torque through them without problems.
I don't know about your area, but AFAIK in Central Texas, truck 12 bolts with limited slip (or Positraction) if you like, are not common at all, and prices usually start at $500.
Oh, new limited slip rears usually run $200-300 and another $200-300 to install.
All the 73-77 GM A-bodies used the 8.5s as well as 73-up trucks. Also many of the 77-up Impalas, the late model ones coming with disk brakes too. These seem to be much more available in junkyards at better prices. Even though you might have to play with wheel backspacing, and weld mounts, its beginning to seem like the better route.
Note I do not have any of these to sell, and this does not in any way constitute an offer to sell any of these.
AusTruck is offline   Reply With Quote
Old 02-27-2010, 04:52 PM   #10
d10s69c10
Built 4 Speed
d10s69c10's Avatar
the 12 bolt for sure.
14 if you want something bullet proof but eats ponies
Or after you get tired of pulling out axles from the truck cause your an idiot like me.
get a **** 9"
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
