Old 02-26-2010, 05:30 PM   #1
grs
Jack For Truck
I need a jack for the truck. What are you guys using. I thought about getting a 2 ton floor jack, and carry it in the bed. I need to build a box for the spare also. I plan to drive the truck from Joliet, IL. to Texas next August for the Good Guys car show. What is a good jack, and where do I buy it.
grs is offline   Reply With Quote
Old 02-26-2010, 07:48 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Jack For Truck
A shop floor jack would be handy to have with you and if you kinda need one anyway.
Something like this would be smaller to be packing around. JMO
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 02-26-2010, 10:45 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Jack For Truck
Why not add a spare tire carrier under the bed?
BTW... I'd recommend going to the Des Moines Goodguy's.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-26-2010, 11:18 PM   #4
grs
Re: Jack For Truck
I may put a carrier under the bed. The wheel is a 20 inch one with a big tire.
It would be real hard for me to handle. The tire is about 10 inches wide.
Old 02-27-2010, 10:43 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Jack For Truck
I forgot you had a spare that matched the other set of wheels on the truck. A carrier under the bed will not work for that type of application.
-Nate
Old 02-27-2010, 11:39 AM   #6
Heartbeat of America
Re: Jack For Truck
I use a 6 ton bottle jack from Northern tools, and a small brick. Fits behind seat on passenger side.
Heartbeat of America is offline   Reply With Quote
Old 02-27-2010, 08:51 PM   #7
airdale94
airdale94's Avatar
Re: Jack For Truck
I wouldn't use a clay brick. It doesn't take much pressure to break one. I like to use cut up pieces of 2x8,10,12.
airdale94 is offline   Reply With Quote
Old 02-27-2010, 10:51 PM   #8
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Jack For Truck
I just bought one of THESE a couple weeks ago, Was impressed with the build quality. Light weight and small enough to lay behind a seat with the two piece handle and just plain sweet lookin....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-27-2010, 11:45 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Jack For Truck
i have a simple scissor jack in my 71 works fine to change a flat i bought mine for like $12 and it don't take up much room.
Hubscrub is offline   Reply With Quote
Old 02-28-2010, 03:43 PM   #10
grs
Re: Jack For Truck
Hey Hubscrub. Where did you buy your scissor jack?
Old 02-28-2010, 03:56 PM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Jack For Truck
our local wal-mart had the gm goodwrench one on sell about a month ago,but they still carry them they just switched to another brand so they had the goodwrench ones on sale they were marked down to about $12 but in the end they are still the same thing
Old 03-01-2010, 06:25 PM   #12
grs
Re: Jack For Truck
Thanks guys. I decided to get a scissor jack for the truck. I was trying to find a good one when I realized that I had one in the garage. It is a heavy duty one. I had it in a box. I take it with me when I go and cut my land with my zero turn mower. I need to weld a socket in it so I can crank it up with a 1/2 inch ratchet.
Old 03-01-2010, 06:40 PM   #13
mr48chev
mr48chev's Avatar
Re: Jack For Truck
I carry a somewhat similar jack and a couple of foot long pieces of 2x6. Sometimes I remember to carry the spare. Don't forget to carry a correct for the wheels and lug nuts lug wrench setup. Also the stock jacks for these trucks still work pretty well in most cases.
Old 03-01-2010, 07:04 PM   #14
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Jack For Truck
I say use the brick for a cruise control and get a nice scissor jack for the liftin!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-02-2010, 04:26 PM   #15
D-Rat
D-Rat's Avatar
Re: Jack For Truck
I hit a local pick and pull and found a never used scissor jack out of a Dakota that I slid under the seat. As for the spare mounting, here's a few pics of how I did mine:
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
