Resident Lurker
Ideal 20" Tire Size?
I tried searching but had no luck (ok, honestly, I gave up after several tries - the "must wait 60 seconds between searches" thing was annoying)
I will be running a static 5.5" drop in front (2.5" spindle, 3" coil) and 5" coils in rear. I've never had 20" wheels before and I'm curious what the best tire size is? The combo I'm looking at getting is 255/40f and 285/40r but I'm concerned about the sidewall height, I don't want the rubber band look. Anyone have pics of a 40 series tire? What about a 45? Thanks in advance. |
Re: Ideal 20" Tire Size?
Google is your friend
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
295.45.20 In the rear......definetly plenty of side wall with six inch drop...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 02-26-2010 at 09:30 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Hey Al,... those rear tires look big!
Are you sure they aren't 295/45-20's? They look bigger than my KDW 295-40-20's.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-26-2010 at 06:23 PM. |
#5 | |
you know what keith? now you got me thinking, when I get home tonight I am going to triple check. I am such a dummy all this time I never realized that they are 295-45-20
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 02-26-2010 at 09:29 PM. |
Here is a tire size calculator you can use:
http://www.miata.net/garage/tirecalc.html Just put your tire size in and it will tell you what you want to know.....
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
my KDWs look that big in that size. it could be because the fornt is an 18" it gives it an illusion
Tot Roddin'
Do you have the specs for this truck you found on google?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Tires are Toyo proxy 255/40/20 and 295/40/20.... First picture in google images if you type in 255/40/20.
Tot Roddin'
Thanks for the info Nova70!
[QUOTE=Nova70;3827028]Google is your friend
![]() I have the specs in my "Stance" folder: 4.5"/7 drop. Front: 2.5" spindles 2" springs Rear: 5" springs 2" blocks 20x8.5 & 20x10 255/40/20 & 295/40/20
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
#13 |
Tot Roddin'
Harrol... thank's for the specs! I went to try and locate the specs but wasn't able too.
