Six in a row makes it go...
![]() Join Date: Mar 2009
HEI thrust washer?
I have some HEI distributors that have a thrust washer between the gear and the housing. Some don't.
Anybody know the deal with that? Is it required? Where can you get them?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
sharp as a marble
![]() Join Date: Jan 2007
Re: HEI thrust washer?
the washer/shim was there to take end clearance away. When the dizzy is spinning, the shaft wants to walk up, or out of the housing. the shim keeps everything in it's proper place.
20' Daredevil (Ret)
![]() Join Date: May 2003
A long time ago (pre-HEI) I picked up a few distributor thrust washers at a Chevy dealership. Can't recall if there were different thicknesses...
Active Member
![]() Join Date: Jul 2007
Good pics on this site and scroll down for info on thrust washers and clearance..
http://www.rustpuppy.org/ignition2/Ignition%202b.htm Also you could check with Napa to see if they have a rebuild kit or a package of shims. Chevy dealers should have them also. Last edited by 68gmsee; 02-27-2010 at 11:27 AM. |
You guys are the best. I knew I'd get a good answer here...
#6 | |
Actually the cam rotation pulls downward on the distributor gear. The main reason to keep the space shimmed to a minimum is to avoid timing variations upon decceleration. When the RPM drops the distributor gear would tend to "float" if there was too much space.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
