Old 02-27-2010, 11:15 AM   #1
chevelle518
Exclamation Steering Column
can anyone tell me how too remove a steering column from a C30 pickup
chevelle518 is offline   Reply With Quote
Old 02-27-2010, 11:51 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Steering Column
unplug the eltrical under the dash remove the plate at teh bottom of the dash ( 4 bolts) go under the hood remove 2 bolts on rag joint then there is a collar on the fire wall remove the collar and then the bracket around it..go back in the cab and remove the 2 bolts holding it in..it should drop the its just a matter of twisting and wiggling it out
Hottrucks is offline   Reply With Quote
