Old 02-02-2003, 02:13 AM   #1
70cst10_05
70cst10_05's Avatar
radiator supports.....diff???
Does anybody know the difference in between67-68 and 69-72 chevy radiator supports, in parts catalogs they say they are different, and i need one for a 70 and have a pretty good one, a little bent but a pretty good one out of a 67 can anyone tell me if this will work??
thanks
kevin
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 02-02-2003, 03:41 AM   #2
GMCPaul
Thumbs up
If you look at your original 1970 support you will see 2 buckets spot welded to the face of it, these are not present on a 1967-68 Chevy support, if you remove these from your 70 support and attach them to the 67-68 it will work in the 1970 truck, there will be unused holes on the bottom front of the 67-68 core support though as the 67-68 used a gravel deflector there not present on 69-72 supports.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 02-02-2003, 04:04 PM   #3
70cst10_05
70cst10_05's Avatar
alright, thanks a lot.
kevin
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
Kevin
Old 02-02-2003, 07:23 PM   #4
72MARIO
72MARIO's Avatar
No Frigin way. I was going to use a 72 rad support on my 67 took off the headlight buckets from my perfect 72 rad support and the holes for the headlights are about 1" off from where they should be . I bought a 67 rad support look closely you will see the diffirence . Still fustrated about wrecking my 72 rad cradel. Later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
