TUKE-NoBullChit Customs owner
voltmeter check?
ive gotten all the other guages working now (big relief) except the voltmeter. i dont really know how to use the "voltmeter" tool, but how can i check out this problem? i know of the brown wire from the alternator, and im sure the alternator works fine because the battery is keeping up a charge just fine. can i try and find the brown wire at the firewall and tap a test light into it while the truck is running or will this burn up something?
Badass
Re: voltmeter check?
use a voltmeter to check and see how much the alternator is putting out when its running.then chase the wires and see if you got any broking or lose connections
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
can i put the voltmeter on the wire at the cab to see if its putting out the same voltage? i knida went crazy with the electrical tape when i put the split loom on and that would be easier than cutting it all off and chasing it physically
#4 | |
The One And Only !!!
That's what I'd do, If you have the same output at the gauge then I'd suspect a bad gauge....If no voltage start stripping loom looking for a break in the wire.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
