Old 02-27-2010, 04:32 PM   #1
StuckinAz
GM ONLY
StuckinAz's Avatar
Rear End Numbers and Ratio
I am in the middle of servicing the rear diff. on my 64 1/2 ton GMC. It has a tag on it that say "46-13" on the top and "3.54". Now i'm thinking 3.54 gears....What is this thing and whats it doing under my truck?
It has patent #'s on it twice and the only other # was C90294 at the top right rear and 44-1 at the right bottom rear. Its a 3 rib on the driver side and 1 rib on the passeger side of the carrier. Any idea what I'm looking at without seeing a pic?
"59 Apache Short Step
"64 GMC Short Wide
"07 Crewcab
"08 Tricked Tahoe
StuckinAz is offline   Reply With Quote
Old 02-27-2010, 11:04 PM   #2
rwgregory
Re: Rear End Numbers and Ratio
Sounds to me like you are looking at a Dana 44 rear axle with a 46 tooth ring gear and a 13 tooth pinion that would calc. out to a 3:54 rear end ratio. What it is doing under your truck is probably pushing it down the road with power from the engine and trans.
All kidding aside, GMC's came stock from the factory with Dana rear axles. 1/2 tons had Dana 44's and 3/4's came with Dana 60's.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 02-27-2010, 11:06 PM   #3
LILRED66
LILRED66's Avatar
Nicely put...
LILRED66 is offline   Reply With Quote
Old 02-27-2010, 11:09 PM   #4
StuckinAz
GM ONLY
StuckinAz's Avatar
That explains it. I couldnt find anything that would help on the GMC. Everything point to 3.55. Thanks for your help!
"64 GMC Short Wide
"07 Crewcab
"08 Tricked Tahoe
