Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-27-2010, 04:50 PM   #1
team39763
Torque converter seated right?
I have an ultrabell on my TH350, a stock 6.0L flexplate and a PI Vigilante LS1/Th350 converter. I thought I had my converter seated good, but a friend looked at it and told me it's not seated all the way and that's why I have to rev my motor sometimes to get it to engage forward gears(only after sitting for a week or two). How much space should be left between the converter and the pump? I can fit my hand back there pretty good. I took some pictures and I'll upload the pics in a bit. From what I read a few years ago, I'm not supposed to have enough space to even fit my hands behind the converter. Does that still apply to a little converter like mine(it's tiny compared to the stock one?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 02-27-2010, 05:29 PM   #2
cableguy0
Re: Torque converter seated right?
If the converter wasnt seated the trans wouldnt work at all. If the hub wasnt engaged to the pump you would know for sure by the extremely loud grinding noise right before the pump was ripped apart. being slow to engage after sitting can be due to bad lip seals sloppy valve body etc etc etc. Its known as morning sickness among tranny guys. Its the first sign of a worn out tranny. You cant fit your hand behind a 12 inch stock converter they are just too big. An aftermarket converter 10 inches or smaller leaves a lot more open space.Dont listen to your friend anymore he doesnt know what hes talking about.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-27-2010, 07:19 PM   #3
team39763
Thanks, that gives me a little bit of relief. That fool had me scared for a minute. He showed me his TH350C and he had what looked like 3/4" worth of spacers between the flexplate and the converter. I wonder how that's gonna work out.
Anyway, my trans is pretty fresh. It was built about 2 or 3 years ago and only has 5 track passes and less than 50 miles on it. The valvebody is a brand new ATI unit. I don't mind the morning sickness as long as the trans will still do it's job at the dragstrip.
Old 02-27-2010, 07:38 PM   #4
cableguy0
Its gonna destroy his pump. The converter being engaged too far is just as bad as it not being engaged.Hes going to find out within minutes why those spacers were a bad idea. There should be no need for any spacers. The trans could last for years. Once it gets warm the seals will expand and seal properly. I would guess it still shifts firm and operates fine once warm.When you put the converter on the trans in the first place you spin it and push it on. it will engage 3 times. Two sets of splines and lastly the torque converter hub engages the pump. You normally bring the converter forward about 3/8's or so so it engages the crank and aligns properly. Thats the reason you had to buy a special converter to use your th350 with the ls engine. the crank flange is different than on the standard sbc everyone is used to.
Old 02-27-2010, 07:47 PM   #5
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
First off, what was his reasoning behind putting the spacers in? You can tell him if it's not to late that he is going to bust his front pump and if he feels you know nothing just keep your mouth closed and ears open and when you hear him squaling about fluid everywhere and his transmission doesn't work you can say " I'm not as dumb as you thought now grab a wrench and help me get this thing out".
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-27-2010, 07:49 PM   #6
cableguy0
Its easier to let some people learn the hard way. The best cure for stupidity is when it costs money.
Old 02-27-2010, 09:20 PM   #7
team39763
I'll tell him what I read on here and see if he'll consider changing it...nobody around this town listens to me since I'm still new to this stuff. It was only 3 years ago that I didn't know the difference between a mechanical and a vacuum secondary carb. But I'm learning. I owe it to him to atleast warn him, that way he can't say "how come you didn't say nothin?"
Old 03-04-2010, 01:13 PM   #8
team39763
Well, the dummy cracked his flexplate this morning. I'm glad I checked here before I listened to this dude. Thanks ya'll.
Old 03-04-2010, 03:41 PM   #9
cableguy0
lol I bet he did more damage than that. The pump is likely torn up inside.
Old 03-04-2010, 06:00 PM   #10
djracer
djracer's Avatar
I personally have never pulled a converter out 3/8 of an inch. I have run a couple of washers if the ears on the convertor aren't thick enough. I would prefer to have the convertor fully engaged but not bottomed out. With Nitrous my junk was close to 1000hp and I sprayed it out of the hole.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-04-2010, 10:15 PM   #11
team39763
I'm pretty sure he used those 5cent spacers/washers they sell here at the grocery store. They were probably all different thicknesses too. I can imagine that flexplate was bolted all crooked.
Old 03-04-2010, 10:41 PM   #12
djracer
djracer's Avatar
that would not be good.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-08-2010, 01:02 PM   #13
team39763
Here's the pictures of how my converter sits in there.
Old 03-08-2010, 01:30 PM   #14
cableguy0
being used to looking at bigger 11-12inch converters which are using in most apps will throw you off looking at that converter. what is it a 9 inch? full size converters are a lot thicker than what you have.
Old 03-08-2010, 03:15 PM   #15
team39763
Yeah I think it's a 9" or 9.5" PI Vigilante.
Old 03-09-2010, 01:25 PM   #16
Marv D
Registered Truck Offender
Marv D's Avatar
I agree 100% with Kevin, and especially if your running a mid plate (steel or aluminum) it's a good idea compensate for the thickness of the mid-plate material between the flex plate and the converter. So in 'some instances' spacers would be the lesser of the two evils.
But, that's just my 2¢
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
