Old 02-27-2010, 08:16 PM   #1
sshockr
Engine twisted in the frame?
I'm swapping in an LT1 which has plenty of flat technically level area on top. If I place a straightedge across the top and measure down from the straightedge the drivers side is 1 in closer to the frame than the same point on the passenger side. 1963 C-10 straight six motor mounts used.
My question is thus; Should the top edges of the frame where the top of the engine mount attaches be equal distance?
This all arose from the 1967 C-10 headers I bought having the number 1 primary hit the engine mount.
Thanks in advance,
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline   Reply With Quote
Old 02-27-2010, 09:44 PM   #2
sshockr
Re: Engine twisted in the frame?
Whilst those are some amazing pictures, I have neither the need or cash for such a set up. I'm thinking if the frame was bent the engine would twist with it. Since the engine appears twisted in relation to the frame, I'm leaning toward the culprit being a bent frame side motor mount.
- Brian
Old 02-27-2010, 10:58 PM   #3
sshockr
So after removal I can't line the 3 bolts back up. If the two in the top rail of the frame line up the bottom one is too far towards the truck centerline. If the one on the bottom is lined up the top two are pushed toward the outside edge.
Was I wrong in assuming the 230 straight six mounts would work for what is essentially a SBC?
Not having a proper benchvise is beginning to be a pain in the butt. I'm beginning to think both mounts are bent. Time to try and find some.
- Brian
Old 02-28-2010, 01:28 AM   #4
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I used the straight six mounts on my SBC with no problems. I'd look for some better ones. jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 02-28-2010, 01:15 PM   #5
sshockr
Bummer sounds like I'm headed to bowtie bits on monday. Thank god they're just down the street.
- Brian
