02-27-2010, 10:17 PM | #1 |
air ride and leveling?
i am very interested in putting an air ride on my 67 but like most people on here i am just a bare bones working on a tight budget and i mean tight... i have thought about running just bags and filling them up at the house and maybe slowly piece together a air management system which leads me to my next question... is it possible to make a air leveling system?
oh btw.. any info on parts for a system i need to find would be great ie. what kind of bags for front and back... maybe a compressor/tank/valves... (im new to the air ride setup so im trying to learn this new lingo and what does what) |
03-01-2010, 11:10 AM | #2 |
Junior Member
Re: air ride and leveling?
You can certainly start out by doing the suspension and inflating it up with a simple set of schradder valves until you get the compressor system lined out.... as far as a leveling system goes.... i would save up and buy one. It is not the easiest task to accomplish
03-01-2010, 02:34 PM | #3 | |
1967custom |
03-18-2010, 04:34 AM | #4 |
Kvn1011
My deville has leveling sensors in the rear, and I believe mark8s do to, but then you'd need to figure out the tech side of it, would be cool, and should be do able, but how much $$$ will it cost vs buying one is the ?
03-18-2010, 07:34 AM | #5 |
Redefining LowBudget
I don't want to step on Tony's toes and leveler's have there place...like in stock cars...but come on guys with the leveler you can slam it ( I maybe wrong about that) and I'm sure you can work a couple switchs
If I was cheap and Poor (which Im) I would buy my bags and enough line to get it plummed to where I was going to mount my electric valves..and put some shrader valves so I can fill them...then save up some ching buy the valves ( 8 of them) and a tank then add that in... keep your eyes open as to tips and secrets that guys have used (like look at my build) and if you can fab alittle you can save alot of money...not always the best or prettyest but it works and its safe..also keep you eyes open for deals locally and here on the board...I maybe getting old but I keep in touch with some of the kids in town..they know where all deals and used stuff is.. |
03-18-2010, 08:43 AM | #6 |
airbagit has some good deals to get started and have instructions on there site to get it done.
03-18-2010, 08:53 AM | #7 |
i'd stay away from airbagit like the plague due to their bad reputation.
go with one of the board vendors ... let's support those that support us. |
03-18-2010, 02:56 PM | #8 |
03-19-2010, 10:44 AM | #9 |
I have thought about this before and i have not tried this yet but here is my thought. You want to have 2 vals for each corner so you can control each bag by its self so you dont get pressure pushing from one side to the other when cornering, but what if you had dual port bags and you ran a line between the second port and put a valve in there... you air the truck up to ride height on level ground, then hit the switch for the valve between the two bags and it opens for just a sec and equalizes the pressure between the two bags and when you let go of the switch the bags are singled back off. Hope this makes since... What do you guys think?
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
03-19-2010, 11:12 AM | #10 | |
Never Done?
03-19-2010, 11:18 AM | #11 | |
I see what your saying tho but it's really kinda of a extra expense that you dont really need.Reason being you already would have the option to level out each corner as need be. |
03-19-2010, 11:42 AM | #12 |
yea i know but if you have ever played with one trying to get the bags at equal pressure you will understand...LOL sometimes it is a pain to get them equal, like alvin said it would not work anyway... it was just a thought, but it has flaws...LOL. I need to slow mine down so I can control it easier...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 Last edited by justpball; 03-19-2010 at 11:42 AM. |
03-19-2010, 04:18 PM | #13 | |
Yeah i'm more the other way w/ air i want faster.I'm actually building a lowrider cutlass.My buddy turned me on to this site and i'm helping him bag a 60's fleetside.It's gonna be sick. I'm actually running Slam specialties HE 7" dual ports in the front of mine w/ dual runs of 3/4" hydraulic line 2 each bag and nitrogen.Got tired of messing around w/ DOT plastic line so i bumped up. |
03-19-2010, 04:42 PM | #14 |
Actually now that i think about it.
If your worried about getting air transfer from bag to bag while cornering.You could do this. 1. Mount your valves under hood.Little bit less air transferring between the tank and valves.It's a small amount in the lines but it might make a little difference. |
03-19-2010, 07:29 PM | #15 |
I have a simple airbag setup using schrader valves.
The front bags each have a ball valve, and then T together and there is one schrader valve. When I fill up, I open both valves and add air, then close both valves. Very easy, and if there is a difference in heights, it is unnoticable. The rear is set up the same way. |
03-20-2010, 11:39 AM | #16 |
hmm sounds like a lot of good brain food
03-20-2010, 06:47 PM | #17 |
I have eight vavles and 2 switchs..along ith guages...it fills even 99% of the time and dumping is quick and easy......I had 4 rockers and the 2 is way easier...If you wanted you could have 4 fill switchs but when you dump all you really need is 2..
BUT 8 VAVLES IS A MUST!!!! or it will drive like crap!! |
03-20-2010, 08:43 PM | #18 | |
8 valves makes for adjusting each wheel dump/fill easier to control.The way your vehicle handles is proportional to instillation and quality of product used. Well that and valve placement like stated above makes a little bit of difference. If your just making a lay and play machine a simple front/back 4 valves set up works.But if your building a vehicle for cornering or a "G" machine then yes a 6 or 8 valves set up you would deff. want to take into consideration. |
03-20-2010, 08:55 PM | #19 |
i agree with the four valve setup, the truck with four valves will handle twice as good as it did with stock suspension if setup right.
03-21-2010, 02:01 AM | #20 | |
Running a 4 valve system (that's front/back) "T" off to each individual wheel per say 2 valves.Yes it would be a little better that using stock OEM sprigs.Reason being you have have the option to control ride height and in turn = control of vehicle when changing the center of gravity.Or pitch or some call Roll what ever Again you want FULL adjustably GO w/ a 8 set up If you want lay and play go 4 |
03-21-2010, 10:02 PM | #21 | |
I'm not sure but in my experiance the 4 valve system will fell soft in the corners...and forget about it if you put any type of load on it...I lay ad play but if needed it works..and WAY BETTER than the old coils
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-25-2010, 03:33 PM | #22 |
Here is one way....Hope this helps
