02-27-2010, 11:25 PM | #1 |
Accuair level sensor mounting question
I've got everything from my Accuair kit mounted except the level sensors. The rears seem like they will be pretty simple to mount, even though I'm using PB tubular arms. I'm going to have to build a couple of brackets, but nothing complicated. The fronts are where I'm kinda stumped. I'm running ART upper and lower tubular arms along with their shock relocators. My problem is, I can't seem to find a location to mount the sensor that doesn't interfere with some part of the suspension. Has anyone mounted theirs yet and willing to share some pictures or insight? Thanks in advance,
Rob Pictures of the rears mounted would be great also.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-27-2010, 11:34 PM | #2 |
Re: Accuair level sensor mounting question
there is an artilce in the new street trucks that shows how to mount them on a 67-72 c-10. i believe it had tubular control arms. i did not buy it, just browsed at it on the rack.
02-27-2010, 11:54 PM | #3 | |
My setup is a little different, but I think I might be able to make their configuration work.
02-28-2010, 10:27 AM | #4 |
no problemo man, i try to help when i can.
02-28-2010, 03:54 PM | #5 |
It'd be alot cooler if you did
is there an article on that truck somewhere?
03-01-2010, 08:10 AM | #6 |
one of the guys at accuair sent me some different pics. i cant find them now.
PM accuair, or they might chime in..... I have seen the sensor mounted on the frame and on the a-arm itself. They welded a tab on the a-arm to mount the sensor. I am going to mount my sensors like they did on the orange truck, makes more sense. I just installed my tanks, compressor, valves, and ECU satruday. I am about halfway done with plumbing the hardlines. hope to mount the senosrs in a few weeks. |
03-02-2010, 04:08 PM | #7 |
Junior Member
We are just finishing up an install with Porterbuilt Front and Rear on our C10. Here are a few pics of how we decided to mount the sensors in both the front and the rear: (We will be starting a build thread for this truck soon!)
FRONT: REAR: |
03-02-2010, 04:49 PM | #8 |
That's pretty sexy Reno! Any dimensions on the spacers and do you have an extra set? .
03-04-2010, 03:17 PM | #9 |
Thanks Reno.
I like the spacer on the back sensor. I have 2" threaded stand-offs that might work for this. |
11-16-2010, 01:48 PM | #10 |
Any more pics of the rear trailing arm setup ? What year C10 are you building up ?
11-16-2010, 05:07 PM | #11 | |
chevy runs deep
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
05-20-2011, 03:59 PM | #12 |
bringing up an old one here but were those blocks available for the rear trailing arm sensor mounts?
08-03-2011, 03:25 PM | #13 |
So when do we get graced to see the build on this one? fount that using 2" stand offs work perfect for the rears to allow adequit clearance for the arm to move and for the guys running complete dropmemebrs and upper and lower controll arms from nate ask me or N2Billet about some shaft collars that not only look nice but fit perfect to mont up the sensors.
06-12-2014, 02:30 PM | #14 |
Pulled this out of the archives... are you guys still making the collars - definitely be in the market for some - running full porterbuilt front and back.
-W
64 Step Side - The Mistress |
06-12-2014, 02:50 PM | #15 |
Go to www.mcmaster.com and look for these part numbers. Should be what you are needing. I am running Porterbuilt on front and rear and these worked perfect for me.
Part# 6436K74 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 1-1/4" Bore, 2-1/16" Od, 1/2" Width Part # 6436K76 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 2" Bore, 3"outside Diameter, 11/16"width
Jay 1956 Chevy 210 Sedan 1970 Camaro Z-28/RS 1970 Chevelle SS 396 (numbers matching L34 car) 1971 Chevy SWB Fleetside with 1967 front clip - in progress My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156 |
06-12-2014, 10:25 PM | #16 |
here's mine.............
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
06-13-2014, 07:52 AM | #17 |
Sweet.. I like the looks of that... I guess I could grab a couple of extra collars for my emergency brake cables in the rear as well.. haven't figured out how to tie that all up yet either. Nice looking build.
-W
06-13-2014, 09:50 AM | #18 |
that's what i'm goin to do also for e-brake..u can drill and tap these collars for almost any type configuration....jim
11-05-2014, 09:24 AM | #19 |
Thanks for the pictures. Is there a reason you chose to attach it to the lower A-arm instead of the upper A-arm?
11-06-2014, 01:46 PM | #20 |
Copied belowme's setup....the one accuair did above in pics had stock crossmember and drag link.....lots more room with PB's setup to experiment.....i like them both actually!......but to answer your question .....just went with what i liked and think will work.....good thing is it can be changed without a lota work if needed...........
11-06-2014, 02:06 PM | #21 | |
11-06-2014, 05:27 PM | #22 |
Wide n'Low
Also curious,
I got my collars delivered today, and my Dropmember should be arriving soon.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
11-06-2014, 07:06 PM | #23 |
yep....that sounds about right...think max was 2.75
11-09-2014, 12:24 PM | #24 |
I picked these up from http://www.littleshopmfg.com. They don't seem to be on their website yet. They are cheap and look pretty good.
11-09-2014, 12:26 PM | #25 |
Here they are on the trailing arms.
