Old 02-28-2010, 09:06 AM   #1
bigdon-70blazer
Tailgate trim installallation blues
On the blazer forum I posted up a question about how to install the tail gate trim and bezels easily. Any help from you guys?
bigdon-70blazer is offline   Reply With Quote
Old 02-28-2010, 10:05 AM   #2
71 super
71 super's Avatar
Re: Tailgate trim installallation blues
Which pieces are giving you trouble? Use lots of the blue painters tape, install the clips into the piece of trim and carefully lay the trim over the holes, making any alignment ness. push slowly and uniformly. If you are using repop trim it bends easily so you might place some lithium grease on the clips the ease installation. I had to drill holes in my nos fenders and this method resulted in no scratches or bent chrome. SLOW and STEADY!
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-28-2010, 04:11 PM   #3
bigdon-70blazer
I get them in the holes alright I just can't seem to get them in far enough to spring the clips completely out for a tight fit. I have tried bending the clips out a little but to no avail...
Old 02-28-2010, 07:25 PM   #4
71 super
71 super's Avatar
Does the gate have any filler around the holes? That can be a problem. Are the clips GM or aftermarket- if after market the units from av-ee-co seem to work the best. Some of the others just will not get the job done. where are you starting the install? You prob. already have the center handle piece in place with the barrell clips. if so start the clip next to it and work toward the end of the gate. I would try a different clip set and give them a good push. Sorry I'M not more help, it would be easier if I could put my hands on it.
Old 02-28-2010, 07:48 PM   #5
powell72
powell72's Avatar
I've had the same issue with some of the aftermarket clips, I ended up snipping the very end of the fingers off the clips to get them to catch.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-28-2010, 08:20 PM   #6
leddzepp
Moderator
leddzepp's Avatar
x 2. I had to do the same thing on some of the aftermarket clips on my trim.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-01-2010, 10:28 PM   #7
bigdon-70blazer
You guys and this forum are AWESOME! I clipped mine as instructed and bingo! Worked like a dream. I knew it just needed a slight bit more and it would release but I had not thought of clipping the ends a bit. Great help! Thanks!
Old 03-01-2010, 10:44 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
OK,... now where's the pics?
Keith
Convert to disc brakes.
Old 03-01-2010, 10:53 PM   #9
bigdon-70blazer
Look over on the blazer side!
