Old 02-28-2010, 03:43 PM   #1
fishingjred73
fishingjred73's Avatar
1968 Radiator support patch panel
Well I never could find any reason why the 69-72 patch panel that Brothers sell wouldn't work on my 68 so I took a gamble and bought one and yesterday got around to installing it. I had to make a few cuts where I could get the new patch in. The inner most inner fender nut is attached the upright on the support.
More pics coming
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 02-28-2010, 03:47 PM   #2
fishingjred73
Re: 1968 Radiator support patch panel
I then trimmed the support and the patch to fit. The patch is a little narrower but I just used all of the nut centers as reference points when I started going back together. Then I took a piece of 1 1/2" tubing to make sure everything was still straight and started welding.
James
Member of
Old 02-28-2010, 03:51 PM   #3
fishingjred73
And here are a couple of the finished results.
James
Member of
Old 02-28-2010, 04:11 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
nice work! better than buying a new one
Hubscrub is offline   Reply With Quote
Old 02-28-2010, 04:50 PM   #5
chuck3026
chuck3026's Avatar
Looks like a solid patch job
2006 Crew cab Z71
1972 Short Wide Step (under construction)
chuck3026 is offline   Reply With Quote
Old 02-28-2010, 06:18 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That is excellent work! looks factory...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-01-2010, 07:32 AM   #7
eagleuh1
eagleuh1's Avatar
Man, I just cut mine to repair the rust. I didn't know they made a patch panel for it. I'm going to go to sheet metal shop and have them bend my metal this morning. Your repair looks great. I didn't have any bolt holes to line up with though. Little bit more advanced cancer.
eagleuh1 is offline   Reply With Quote
Old 03-01-2010, 08:38 AM   #8
fishingjred73
I had the inner bolt hole left and the spot for the outer. I just used the left side holes.
James
Member of
