Old 02-28-2010, 11:42 PM   #1
dlisabeth
Aftermarket steering column
I am about to purchase an ididit replacement column for my truck. It is part #1140650010 and is a bolt in replacement for our trucks. It also has a column shifter on it for the 700r4 I am using. It is a bit pricey at $550 and I want to make sure there are no other bolt in options before I make the purchase. Please let me know if you guys know of any other options.
http://www.summitracing.com/parts/IDT-1140650010/
Thanks,
Derek
dlisabeth is offline   Reply With Quote
Old 03-01-2010, 12:07 AM   #2
72bigred
Re: Aftermarket steering column
People commonly use the 70's chevy van columns, they are not direct bolt in but very limited mods to get them into place working nicely, thats what I installed in my wifes 60. There are multiple write ups about them if you do a search and I have seen some rebuilt ones go on evil bay for around 300$ and non rebuilt for of course under that.
Reid
72bigred is offline   Reply With Quote
Old 03-01-2010, 02:16 AM   #3
Scottshotrods
Thanks,
Derek
Derek,
We can give you a better price on Ididit if you like to purchase one.
You can P/m me or e-mail me justin@scottshotrods.com or call
(805)485-0382
justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 03-01-2010, 11:36 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
I used the van columns. Just lined them up and tack on some nuts so I could bolt it to the bracket under the dash. I got the last one at PNP on a 25% off day for $28. This was back when they were not ripping people off though.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-02-2010, 12:18 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Thanks,
Derek
The only other thing I would recommend is purchasing a Borgeson U-joint steering adapter. If you go with a .75" DD shaft, the part number I used is: 013449 - it's a .75" x 36-spline to .75" DD adapter joint.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-14-2010, 09:39 PM   #6
60apache
60apache's Avatar
did you end up buying the column?
60apache is offline   Reply With Quote
Old 08-17-2010, 12:05 AM   #7
dlisabeth
Nope, I ended up getting a 70's van column that I will be installing soon.
1965 Shortbed stepside Chevrolet C-10
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=409676
