Old 02-02-2003, 02:49 PM   #1
Mudder
Mudder's Avatar
Question Aftermarket guages/ Cluster
Gonna try to use Sport Comp Autometers and was wondering if they will fit in the smaller holes or if they have to be made bigger? What size guages work?
Mudder is offline   Reply With Quote
Old 02-02-2003, 03:20 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Mudder you can use 2 5/8 for the 4 lower holes.A 3 3/4 guage such as fuel pressure for the factory tach hole and 5 in guages in the 2 big holes ...All you need to do is cut around the inside of the hole to remove the tapered edge. Then the guages should slide in from the front of the pannel.....Be careful when cutting not to heat up the plastic cause it will get all gooey....Hope this helps
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-02-2003, 03:21 PM   #3
Mudder
Mudder's Avatar
Thanks thats just what I needed to know.......
Old 02-02-2003, 07:51 PM   #4
Blue Beard
Blue Beard's Avatar
Gauge Links
Mudder:
Can't remember which site had good articles on this change.....
Try the following......
67-72suburbans.com/articles
73-87.com/misc/sitemap.htm
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-02-2003, 07:58 PM   #5
Mudder
Mudder's Avatar
Thanks a bunch!
Old 02-02-2003, 08:04 PM   #6
Purs
Got Big Block?
Purs's Avatar
Hey Mudder, I'm thinking about going back stock. PM me if your interested in my cluster. I'll post some pics tonight.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 02-02-2003, 08:05 PM   #7
THOR 50
Over worked under paid
THOR 50's Avatar
another idea
You can also mount them from the back side. Giving them an original look.
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 02-02-2003, 08:35 PM   #8
rayville body
THOR is that your cluster? lets see more pics and info on how you done that. looks great!
rayville body is offline   Reply With Quote
Old 02-02-2003, 08:49 PM   #9
I'd be interested also THOR in seeing what you did.
Old 02-02-2003, 08:50 PM   #10
THOR 50
THOR 50's Avatar
no pics
I did this several years ago so I've probably missed something but you get the idea.
Use a seperate piece of lite weight metal to mount the gauges in, lining them up with the holes. (used my bezel as a template) You won't be using the old gauge parts at all. Mount the metal from behind the dash. make sure to cut out so that your light and wiper switches will clear and put holes for the bezel screws to clear. You may need some nylon spacers to get the guages flush with the bezel.
The main pain in the butt is getting your turn signal indicators to work with out the circuit board. A couple of pre wired blub sockets should do the trick. And save the little card board tubes as well as the green lenses
I think it's a little more difficult way to go but worth the effort. The gauges run about $500 new from Autometer. If I was to do it over I'd use a tach on the left, large speedo on the right and fuel gauge in center.
Roger
Old 02-03-2003, 12:14 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I used 2 inch guages in mine. They sit down in the bexel hole pretty good, showing the chrome on the bezel pretty good. Mine are affixed to the bexel its self, and mounted with the retention that came with the aftermarket guages.
Old 02-03-2003, 12:22 AM   #12
Mountain Man
I mounted Autometer comp gauges in my new dash, and painted the stock speedo and fuel gauge to match. I like it.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
