Dropping the back of a 60-66 with leaf springs
Kinda new at this. Not gonna use bags (For Now).
What's the cheapest and safest way to drop the ass end of my truck? Any sugestions would be much appreciated.
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 Last edited by REDNOSE65; 03-01-2010 at 02:22 PM. |
Justified!
Re: Dropping the back of a 60-66 with leaf springs
Hey, I just asked this same question yesterday.......
Shackles......cheap heat leaf springs or remove leafs......cheap drop mono springs......expensive.... do axle flip......cheap, but a big drop...like 5" can you bag it if you have leafs? I would think you would have to get rid of the leafs and go the floating rear end deal with springs, whatever that is called....
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
SSN 706
About 500lbs of sand should do the trick.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-01-2010 at 03:33 PM. |
#4 | |
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
SSN 706
Any time
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-01-2010 at 03:52 PM. |
How low do you want to go? Shackles or flip kit would be cheap. Probably need c-notch with the flip kit though. Never heat springs!!
SSN 706
Would'nt shackles raise it?
#8 | |
#10 | |
Don't think Ima c-ntch it...I don't know enough about it. I'd like to lower 3 maybe 4 inches in the back and maybe another 2 in the front.
Justified!
If you use shackles, they lengthen the spring,and lower the overall frame height.....
They are fairly cheap, running around 60.00 bucks......
I just called a local hotrod shop and they said they did'nt have shackles that far back. Any ideas where I can find them???
#13 |
Happy to be here
![]() Join Date: Mar 2000
#14 |
Decide on what drop you want first. It's usually much easier to go w/a flip kit vs. trying to find shackles & hangers (definitely easier to build). If you're set on shackles & hangers, parts for a 71-72 should work w/minor (if any) tweaks.
About the rear shackles: Dropped shackles are longer vs. stock. Since the shackle acts as a pivot point, one end stays fixed to the truck, the other is attached to the end of the leaf. With the longer shackle, the end of the leaf mounts higher vs. where it would have been originally. That difference in locating heights would be the amount of drop. It would raise the truck if the shackle pivoted down (but they pivot up on trucks). You can always swap to truck arms & coils too....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-01-2010 at 08:33 PM. |
#15 |
1961 crewcab
by far i think the easiest would be a flip kit, and then a c notch and lowering blocks if it is still not low enough...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#16 |
![]() Join Date: Jul 2003
Cpp sells drop leaf springs for that, I just sold some to davestrucks.
#17 |
Justified!
I just installed my shackles........It made a big difference......And fairly easy also.....
#18 |
Flip kits for trucks (60-72) w/2.25" wide leafs....
http://www.stylintrucks.com/part.asp...2&scid=FROOGLE
#19 |
Thanks for the info guys...still doin my homework see what will work best for me.
#20 |
I did a flip kit on my 72 without doing a C-Notch. I have 8000 miles on it now, and have purchased a C-Notch kit. I do not reccommend a flip kit without a notch, it's just too close.....
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
#21 |
![]() Join Date: May 2009
Take 3 leaves out that will lower it 4" if you want more use shackles CPP has them and you will need to get shorter U-bolts....Vernski
#22 |
Resistance is Futile
I second that. My truck has leaf springs and with the flip kit the axle is just about at frame level. It's a good look.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 03-04-2010 at 12:08 AM. |
#23 |
CLASSIX Truck Club
Any pics Vernski?
#24 |
#25 |
There's one in every crowd . . .....
