Whats better shielded or wrapped?
Im about to order some stuff from Summit (an order code would be nice
![]() Shield: Looks great, last long, may not keep heat away as well Wrap: Looks ok, probly wont last as long, probly works much better for keeping heat out. The reason I have thought about this is because sometimes after alot of driving, or when trucks hot. It doesnt start as good. Im thinking its heat soak the starter, but I dont know for sure. Either way I plan to get one, it should help some, even more when I get the headers, plus it will look better. Just want to get your thoughts Here is the shield in question: http://store.summitracing.com/partdetail.asp?part=10931
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
yeller
Eddie, when I was running my small block I tried both. The heat shield was the first thing i tried...but no matter what i did, I could not get that SOB on...to tight of a fit and not enough room to move it around. So I tried the starter wrap...worked great!! You simply cut it to the width of your starter and secure it in place with giant hose clamps. The only tricky part was getting the clamps in the right position so when you installed the starter it would fit and clear the headers (if you have them) and tranny lines as well. I had mine on there for over five years and was very happy with it. Hope this helps a little.
-Jeff |
Eddie ,we both drive in the same heat and when I had that problem on my truck I just put a new starter in and had no more trouble. Some guys use the mini starters especially with headers to avoid heat problems .
Do you live in AZ too?
When the starter is brand new it doesnt seem to do it as much. It doesnt do it all the time either, just most the time ![]() Jeff what heat shield did you try, or does it even matter?
