Old 03-01-2010, 05:04 PM   #1
robzilla
robzilla's Avatar
parts truck
here's a few shots of a parts truck i'm gonna pick up in a few days. hoping to use most of the front end to convert to disks, and 5 bolt pattern.
any ideas on carb brand?
with some cleaning up, hopefully i'll be able to use most parts.
general engine pic,
the guy mentioned it was a 4 bolt 350, where do i find the stamp on the block? how do i tell which heads are on it?
it has a twelve bolt rear end.
do these numbers tell what gears are inside? or is there another tag?
robzilla is offline   Reply With Quote
Old 03-01-2010, 06:38 PM   #2
evilways
evilways's Avatar
Re: parts truck
As far as the axle info I think you need to id the axle stamp numbers to find out what was in it stock.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 03-01-2010, 06:42 PM   #3
powell72
powell72's Avatar
Re: parts truck
Carb is a factory replacement Holley, engine code will be on the driver's rear of the block behind the cylinder head, and the head numbers will be under the valve covers.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-01-2010, 08:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: parts truck
3.07 gears is what it should have if still original
Old 03-01-2010, 08:19 PM   #5
robzilla
robzilla's Avatar
Re: parts truck
will the 3.07gears be ok for a cruiser?
Old 03-01-2010, 08:20 PM   #6
robzilla
robzilla's Avatar
Re: parts truck
thanks, is this carb worth rebuilding?
Old 03-01-2010, 08:30 PM   #7
robzilla
robzilla's Avatar
Re: parts truck
what about the front end parts? will the work to put on my 69? what should i be looking out for? this should bolt on?
Old 03-01-2010, 09:57 PM   #8
ERASER5
ERASER5's Avatar
Re: parts truck
3.07 gears are definitely cruise worthy, unless you go with an overdrive.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-01-2010, 10:06 PM   #9
Longhorn Man
Re: parts truck
Exactly!
The 3.07 is the most freeway friendly gear that came in these rigs. If you add an overdrive, then odds are the RPMs will be too low and hurt MPG.
Old 03-01-2010, 10:07 PM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: parts truck
The front and rear will bolt into your '69 . There are 14 bolts that hold the front
xmember in the frame, 12 of the 14 will line up when installing in the'69 , just elongate the other two and you will be on your way. Search the site
there are several threads on it. Best of luck.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-01-2010, 11:13 PM   #11
powell72
powell72's Avatar
Re: parts truck
A little tough to call from the two pics, but I don't see why not.
Chris
Old 03-01-2010, 11:53 PM   #12
robzilla
robzilla's Avatar
Re: parts truck
a couple more questions: the power steering and brake booster, these would be another couple of parts to take off the 72 parts truck for my 69?
i orginally planned on getting this parts truck for the windshield.
Old 03-03-2010, 09:43 PM   #13
oldmanlance
oldmanlance's Avatar
Re: parts truck
how can u tell what it has by the # on the rear end , and what do u look for to tell ?
oldmanlance is offline   Reply With Quote
Old 03-03-2010, 09:56 PM   #14
powell72
powell72's Avatar
Re: parts truck
Those parts interchange also, you'd need to use a disc/drum master regardless.
Chris
