Old 03-01-2010, 05:25 PM   #1
k5hart
k5hart's Avatar
Removing Rear Hangars
I'm going to have to go to the junk yard and pic up some factory hangers to replace the dropped ones on my truck? How hard of a job is it to get them off? Am I right in thinking the factory used big rivets?? Thanks for the info.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 03-01-2010, 10:57 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Removing Rear Hangars
Are you talking about the front or rear spring hanger brackets or the shackles ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-01-2010, 11:13 PM   #3
k5hart
k5hart's Avatar
Sorry I wasn't too clear was I. The front hanger bracket.
Old 03-02-2010, 12:06 AM   #4
Restrorob
Restrorob's Avatar
Those are riveted to the frame and some what a pita to get out especially in a junk yard. I ground the heads off my 74 with a angle grinder then drove them out with a drift punch and BFH.
Unless you can get them to move the truck near a power source or get them to cut the heads off with a torch I'm not sure how you would get them out, A BIG chisel and BFH may do it but could damage the hanger if not careful....
Best of Luck !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-02-2010, 12:24 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I've been cleaning out my garage, slowly working my way to the pile-o-parts that are un-needed. I may have a set of hangers, but I can't guarantee it. I have not laid eyes on them in about a year.
Member Nr. 2770
Old 03-02-2010, 09:13 AM   #6
BigBlocksRule
If you make it to the junkyard, make sure you get the right ones, GM changed the shape slightly in the late '90's and the rivet holes are different.
BigBlocksRule is offline   Reply With Quote
Old 03-02-2010, 10:32 PM   #7
k5hart
k5hart's Avatar
Good info guys. I was afraid it may be hard. I would be interested in buying some if you have them chevloray. Any idea when they changed them BigBlocksRule.
Old 03-03-2010, 12:16 AM   #8
BigBlocksRule
Look for drop hangers on sleazebay, there's at least one seller on there that advertises the year break. Seems like it's late in this model...
Old 03-03-2010, 12:39 AM   #9
lurch115
lurch115's Avatar
doorman makes factory replacement leaf spring hangers. here is a link.
https://www.dormanproducts.com/cgi-b...rid=0x00438678
i just looked it up using my truck's specs. so they may not be exactly what you need.
it won't give you a price but you should be able to find a local auto parts store that sells their products.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-06-2010, 01:43 PM   #10
k5hart
k5hart's Avatar
Man, ya'll weren't kidding about these being a pain! I found a truck at the yard without a bed and tried to drill out a rivet. I gave up. Still got the shackles so it was still a sucess. I'll order the Dorman hangers. Thanks for the help again!
Old 03-07-2010, 09:50 PM   #11
k5hart
k5hart's Avatar
Well, new update. The dorman hangers are for the rear. I needed the front. They are not so easy to find. Latemodelrestoration.com was the cheapest at $99 a side. So....back to the yard I went today. Bought a $14 1/2in. drill at Lowes on the way, took my big drill, and got the hangers off. $5.99 a side. So, for $26 bucks and some sore arms I figure I saved about $175. And it was kind of fun hammering off the heads of those rivets. Good stress reliever!
Old 03-07-2010, 11:28 PM   #12
Restrorob
Restrorob's Avatar
Kudos to you for tackling that job with a drill, Me.....Naaa !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-08-2010, 01:27 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Haven't been on the past couple of days, so I missed the comment k5hart....but glad you found some and got em. I haven't found mine. They're off of my '96 regular cab SWB....if I find them.
Member Nr. 2770
