Old 03-01-2010, 07:47 PM   #1
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
What is this?
On a 1969 Chevy 307 with at least a 10gauge red wire going to it, what is this?
Beatcoaster is offline   Reply With Quote
Old 03-01-2010, 08:02 PM   #2
697498chevy
Re: What is this?
Don't know , but my '69 307 doesn't have one .
697498chevy is offline   Reply With Quote
Old 03-01-2010, 08:04 PM   #3
OhOneWS6
OhOneWS6's Avatar
Re: What is this?
Fast idle solenoid to bump the idle up when the AC is on. It compensates for the drag on the engine when the compressor is running.
OhOneWS6 is offline   Reply With Quote
Old 03-01-2010, 08:10 PM   #4
Beatcoaster
69 Fleetside
Re: What is this?
Funny, my truck doesn't have A/C, but this does look factory and is tied into the fuse panel(not another carb the p/o swapped on)....weird
Old 03-01-2010, 08:14 PM   #5
OhOneWS6
OhOneWS6's Avatar
Re: What is this?
No other reason that I am aware of for that solenoid. Maybe someone swapped the wiring harness. Is the wire inside the harness or was it run separately? Maybe someone did a motor swap at some point and took the harness as well.
Old 03-01-2010, 08:29 PM   #6
67vetteal
Re: What is this?
Put Voltage to it and see if it works. Worth a few dollars on Fleecbay! Al W.
67vetteal is offline   Reply With Quote
