Old 03-01-2010, 07:51 PM   #1
85burb
85burb's Avatar
Speedo cable keeps breaking
Has any one had problems out of a 700r4 np 208 speedo cable. mine has broke 4 times now and i put it back in the factory holders. seems like every 6 mounths it breaks. any ideas would help.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-01-2010, 09:07 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Speedo cable keeps breaking
Are you using any type of lube? Use a light coat of lithium grease. Where is it breaking?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-01-2010, 10:17 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
is it a cheap chinese reporduction?
or is your truck really realllllly fast?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-01-2010, 10:55 PM   #4
datguysaL
check it, make sure it dont got any hard bends.
datguysaL is offline   Reply With Quote
Old 03-02-2010, 12:28 AM   #5
85burb
85burb's Avatar
i lubed it with the hole pack of clear greas it came with. I followed the factory routing on the cable it has the bends it came with i beleve. and my burb would like to think it is fast.. come to think of it i did race a avalance today..... but it broke like 30 mins later. and i hit a top speed of maybe 55 mph in said race.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-02-2010, 01:23 AM   #6
dammitmitchell
the pollock
are you buying the same cable over and over again?
i have a feeling it's a cheap cable...
is it really close to your exhaust?
i had one break due to it laying on my pipes, that or a cheap cable ....
Army vet 02-08
Old 03-02-2010, 12:18 PM   #7
85burb
85burb's Avatar
only one got melted on pipe. all the other ones broke at the turn to go over trans it makes like a 100 degree turn in like 2.5 feet. but that is how it was from the factory. i put it in the little holder things.
2 of them were used.....cheap actually cost more then the new ones ha ha
2 were new... pepboys the only one they sell.
what is a good brand? where can you get it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-02-2010, 02:14 PM   #8
dammitmitchell
the pollock
mines run up the side in a "big arc" there's no tight bends,to the frame and then it's tucked against the firewall until it's ready to enter through.
i diddnt get an lmc one i bought mine at napa
Army vet 02-08
Old 03-02-2010, 02:50 PM   #9
85burb
85burb's Avatar
sounds about the same path as mine. just went to auto zone and got price for new one. 10 bucks. does not sound like a winner. i am about to install my trans pan today so i will look to see if it is really broken again. bet it is. thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-02-2010, 03:14 PM   #10
Orange
Licensed to Thrill!
Orange's Avatar
Pick you up a Lokar and be done with it. You can justify the cost of one vs. 15 of the cheepies.
Just pertaining to the 700R4 I have the Lokar column shift assembly, Trans. Dipstick, Speedo Cable and the Throttle (TV) Cable. Can't go wrong with it IMO.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-02-2010, 08:22 PM   #11
85burb
85burb's Avatar
DLB
Thanks i will look that up.
looks like i melted it on pipes again.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-02-2010, 09:53 PM   #12
datguysaL
well, i was gonna say to check your engine mounts and tranny mounts, they could be letting the trans move and cause the angles of the cable to change. and it causing it to bend too much and break. but then again, you should be able to feel or hear the ka-clunk!
but yeah, moving that big beast will sure produce some heat out the exhaust, just throw some heat wrap on it when u replace it.
oh, so did u beat the avalanche??
Old 03-02-2010, 10:04 PM   #13
85burb
85burb's Avatar
I just replaced my mounts a few weeks ago. Heat is def produeced when i drive it. I am usally not to nice to it.
and about the race i lost due to slow start. i figured we were going to race but did not just want to punc i off the line and look like a dork. so i took off slow and he punched it and then i did. i slowly gaind on him. i started out at his tailgate and ended up by last door. think i could have taken him tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
