Old 03-01-2010, 11:12 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
What is this?
1979 K10, 350, TH350, NP203.
I was cleaning out the linkage and found this random wire dangling. What could it be to?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 03-01-2010, 11:15 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: What is this?
Looks like the plug for the back up light switch....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-01-2010, 11:16 PM   #3
Benelli
Benelli's Avatar
Re: What is this?
Oh. Might want to get that fixed.
Old 03-01-2010, 11:17 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Re: What is this?
follow it.
it looks like it could be for the low range indicator in the dash, was it going under the truck between the floor and the t-case shifter boot?
edit: the back up switch is on the column, we are looking at an auto
95 S_Trucker is offline   Reply With Quote
Old 03-01-2010, 11:18 PM   #5
Benelli
Benelli's Avatar
Re: What is this?
Well, I could tell the PO had taken off that panel shortly before I bought it and it was wedged between the access panel and the floor.
Old 03-02-2010, 01:41 AM   #6
Gregs71
Re: What is this?
I have a similar plug like that hanging down between the frame and the dr side gas tank. Except mine has two holes (yours appears to have one). My truck is a 1987 350/th400 4x4, and everything appears to work.
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 03-02-2010, 10:08 AM   #7
68 TT
Still plays with trucks
68 TT's Avatar
Re: What is this?
That looks like a T-400 kickdown connector that plugs into the driver side rear area of the T-400.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-02-2010, 11:27 AM   #8
James McClure
One shot, one kill.
Re: What is this?
It's a THM350 so the down shift is a cable. Back up lamps are on the colunm as is neutral start switch (in one switch) Is it possible it could be for a TCC? Look on the left side of the trans case for a connector (probably white) with 2 spades sticking out. I don't remember when they started with TCC transmissions. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-02-2010, 01:51 PM   #9
Damien
Damien's Avatar
Re: What is this?
The th400 could have been swaped to a th350 or it could be for the tq converter lock on a th350C. I think '79 was the first year for the th350C. The th350C will have a plug on the passenger side of the trans near the dipstick tube and cooler lines.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-02-2010, 02:15 PM   #10
68 TT
68 TT's Avatar
Re: What is this?
I know the 700-R4 shares the same plug opening size in the case as the T-400 since you can use the T-400 plug on the 700-R4 when doing a transplant to wire up the TCC function. Makes sense that the T-350C used the same plug too.
Sounds like somebody swapped out an earlier T-350 for a worn out T-350C and just put the unused plug out of the way.
Old 03-02-2010, 05:38 PM   #11
Prong
Re: What is this?
It looks just like the plug for the 4wd switch that bolts on to the Tcase shifter.
Prong is offline   Reply With Quote
Old 03-02-2010, 08:21 PM   #12
willett
Another Day, Another Dollar
willett's Avatar
Re: What is this?
my '78 203/400 has the same mystery connector hanging down.
i'm thinking its a low-range indicator.
i had always noticed it dangling around when i looked around the t-case area, and when i pulled the carpet i found it running along the floor and under the shift boot.
try hooking 12v up to it while the truck is not running and see if it lights anything in the dash up. and let me know!
ed. and my kickdown functions just fine without it connected.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-02-2010, 10:44 PM   #13
USSkoval
Re: What is this?
+1 for 4x4 indicator.
USSkoval is offline   Reply With Quote
