Old 03-02-2010, 02:32 PM   #1
1979blkchevy
1979blkchevy's Avatar
True or False???? Explain Please
I have a 1983 chevy silverado 3/4 ton with a 6 inch lift on it!! Could i get another driveshaft from another chevy truck or truck that will fit right in with a 6inch lift or do i have to have a driveshaft extened??? thanks in advance
1979blkchevy is offline   Reply With Quote
Old 03-02-2010, 03:36 PM   #2
Re: True or False???? Explain Please
True,you have to extend your driveshaft.False,I don`t know of any shaft from another truck.My last`72 needed 2" with a 6" lift.I`m preparing to do another,but I won`t just go and get the shaft made 2" longer.I feel better getting it back on all fours and measure.It`s not rocket science,I just have bad luck with tryin`to make things easier.One step ahead at a time never fails.
Old 03-02-2010, 08:49 PM   #3
Mike C
Mike C's Avatar
I agree. You should get 'er on the ground and measure.
It is possible to source junkyard driveshafts in lots of different combinations you might could piece together what you wanted. crew cab, suburban, blazer, regular cab, long bed, short bed, slip yoke front, fixed front, NP208, NP 231, NP 205, NP 203, 1310, 1330, 1350 u-joints.
Each one of these is a little different so you might find a combination that would work. But how much time do you have? And how many 4x4's are in a junkyard near you? Put it on the ground, measure, and order a new one IMO. My original shaft was whacked. Splines worn, yokes worn, possibly bent. It made it 300k miles, but it was time.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-03-2010, 12:05 PM   #4
1979blkchevy
lol junk yards near me is slim to none my driveshaft is totally shot im not to sure on how to messure what i need!!!
Old 03-03-2010, 12:12 PM   #5
Keith Seymore
Keith Seymore's Avatar
Usually the shop that fabs the shaft will have a very specific way they want you to measure it.
I measured one up onetime and took all the details in to the shop; they sent me home to re-measure it their way!
They'll tell ya how they want it done -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-03-2010, 07:52 PM   #6
Mike C
Mike C's Avatar
Yup, you all need to be on the same page when measuring. I have purchased shafts mail order from Six States Distributors, Tom Woods, and Wenco. I know we have at least two driveshaft shops around Austin, so pick your poison.
44 Willys MB
52 M38A1
64 Corvette Coupe
