Old 03-02-2010, 05:08 PM   #1
Hammer500
Hammer500's Avatar
69 Steering Components
Hi Guys,
I have a 1969 Chevrolet C-20 4x4 and I have one worn ball joint and steering arm or drag ling from the steering box is worn as well. The truck has power steering too. I can't find any listings for these parts. Always 70-72. Will the parts from the 70-72 work or are they different?
69 Chev C/10 350/200 4R LWB
69 Chev K/20 4x4 350/4sp LWB
69 GMC Sierra Grande 396/400 LWB
Hammer500 is offline   Reply With Quote
Old 03-02-2010, 05:42 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 69 Steering Components
I would bet that the drag link ends would be the same but the 69 should have the closed knuckle Dana 44 and I don't think it has ball joints like a 70-72 open knuckle Dana 44 would have.
Here is my 1969's closed knuckle Dana 44
And here is a 1978 open knuckle Dana 44 (will be about the same as the 70-72)
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-02-2010, 06:02 PM   #3
Hammer500
Hammer500's Avatar
Yes it has a closed knuckle 44. Have you had to buy ball joints or drag link ends for your 69?
Old 03-03-2010, 11:23 PM   #4
Hammer500
Hammer500's Avatar
I have been doing some more reading. Do the closed knuckles even have ball joints or are they king pins? I jack the front corner up and was moving the tire top to bottom and I have a lot of play on the bottom and my buddy looked in and said it was the lower ball joint. I have no experience with the closed knuckles at all. Can anyone give me some guidance.
Old 03-04-2010, 03:53 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Brief research I just did indicates the closed knuckle would be king pins rather than ball joints. I confess I don't know much about the closed knuckle even though I've had one for 10 years.
If it were me I'd start looking for a later year Dana 44, gain disk brakes and better turning radius plus better availability of parts. I recently blew up the bearings in my closed knuckle and just got done upgrading to a Dana 60.
As for the drag link ends, you'll be fine with ones listed for like a 71 or 72 axle.
Old 03-04-2010, 11:07 PM   #6
msgross
msgross's Avatar
ditto, I did the 10-bolt upgrade...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
